Electrical Supplies Logo
d
donna maranto Posted on Mar 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there a reset button on the badger disposal?
Terry
Level 3:
  • Master 11,377 Answers
  • Posted on Mar 20, 2018
Terry
Master
Level 3:
Answers
11377
Questions
Helped
4619648
Points
152765
Steve Pack
Level 3:
  • Electrical S... Master 7,121 Answers
Steve Pack
Level 3:
Answers
7121
Questions
Helped
2271480
Points
27874
If your garbage disposal won't run you may need to reset the garbage disposal using the RED overload protector button on the bottom. ... Turn on a cold stream of water and turn the disposal switch to "ON" position, the disposal should now run again. How to Reset Garbage Disposal InSinkErator
Use the wrench provided and turn disposer counterclockwise wise (of course the power is off.. do not repair it is better to replace with a new unit. Use 1/2 Hp minimum. Available at HD or Lowe's
5 Related Answers
Anonymous
  • 2992 Answers
  • Posted on Jan 28, 2009
SOURCE: BADGER GARBAGE DISPOSAL just humms. does not work.
It sounds like the disposer has something jamming it. Try using the breaker wrench supplied with the disposer (or a suitable-size hex wrench) fitted into the socket on the bottom. Rock the wrench back and forth to see if you can loosen the jam. Another trick is to use a wooden rod (end of a broom handle, for example) to push on the blade to try dislodging the jam. Look inside with a flashlight to see if there is something that is easily missed. (I have found drink can tabs, coins and a shelf clip that way.)
It's also possible the motor starting capacitor inside the disposer or the motor itself is bad, in which case you would probably spend less on a new disposer than on repairing this one. But a jam is more likely.
Anonymous
  • 247 Answers
  • Posted on Mar 23, 2009
SOURCE: garbage disposal leak
Don to install a new one.
don't think it is a DYI and by the time you call for service it would be cheaper and use your DIY.
Hope this is a FixYa
Please rate the answer
Kurt
Fred Yearian
  • 5603 Answers
  • Posted on Dec 30, 2009
SOURCE: badger 5 garbage disposer does not grind
Some say to put a load of ice cubes in and run it.
Anonymous
  • 82 Answers
  • Posted on Jan 24, 2010
SOURCE: humming noise when turn on insinkerator badger 5XP
Your disposal is stuck. Sounds like something either fell in it, or perhaps a bone got inadvertantly tossed in. Do you own an allen wrench set? The garbage disposal did originally come with one, but it usually gets lost. The one that came with it will look like two hockey stick stuck together. In any event, you need one for the fix. There is a hole on the bottom of the disposal, directly in the center. Find the correct size allen wrench and place in this hole. Twist clockwise and counter clockwise until it is free. Once this is done, you most likely will need to hit the reset button on the bottom. Good luck!
Anonymous
  • 43501 Answers
  • Posted on Sep 29, 2010
SOURCE: Our Badger 5-81 garbage disposal stopped working.
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
d
1helpful
Is there a reset button on badger 15ss?
Usually the reset button is located on bottom of disposal near where wire is connected..
Use your hair mirror to look at bottom of disposal.
More disposal resources for troubleshoot, maintenance, repair and installation:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
The badger 5 has just stoped working
There are three possible things.
1) Circuit breaker tripped
2) Wall switch gone bad
3) Reset button tripped on disposal
Reset is located near where wire connects to disposal
MY BADGER INSINKERATOR XP IS NOT SPINNING AND THE RESET BUTTON IS NOT RESETTING. WHAT WRONG.
It sounds like the garbage disposal has a fatal short, and the reset won't push in because there is an electrical failure inside the unit.
Badger 5+ quit. no sound no jam; got power to unit. 5 or 6 yrs. old. replace?
Did you reset the circuit breaker on the disposal? There should be a button on the bottom of the disposal unit.
InSinkErator Badger 5, 1/2 HP Garbage Disposal: I have a Badger InSinkErator, it suddenly just sto...
Here is a tip the I wrote that may help you to figure out what is going on withyour garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Our SinkErasor Badger 5 doesn't work.Wrenchette can't be rotated
MAKE SURE THERE'S NO STUFF INSIDE THE DISPOSAL. PUSH RED RESET BUTTON, (USUALLY UNDERNEATH OR ON SIDE) IF THERE IS ONE. THE DISPOSAL ALSO CAN BE TURNED USING A 1/4INCH ALLEN WRENCH. USUALLY INSERTED IN BOTTOM UNDERNEATH OF DISPOSAL.
8helpful
Water leaking out of bottom of unit, near reset
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
p
4helpful
The motor on my Badger 5 disposal was humming but not rotating. I cleaned out all the debris, reset it and now there's nothing - no hum, nothing. Is my badger dead?
The badger 5 has a dislodge device on the bottom right in the very center. An allen wrench will fit if you have lost the tool that came with it.
FIrts you will need to dislodge anything preventing it from turning. (Insert the right size allen wrench and turn both directions) The remove whatever comes loose after dislodging.
Then opush the red reset button on the bottom. Check the breaker that powers up the disposal, as you may have tripped it.
If the breaker is on, the unit is turning freely, and the reset button is pushed, then the next step is to check for power using a volt meter, to make sure the disposal is indeed getting power. If all the above has been done, the unit IS getting power then yes, the disposal needs to be replaced.
Top Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
