Question about Video Game Consoles & Games
Hawk 2 quadcopter drone187 on/off switch location on craft can't find it
Posted by Shane King on
I did check all the propellers and they were ok I would like to contact the seller but I don't have any address to do so I am hopeing it is still under warenty
What is the issue with the quadcopter?
All propellers spin but it flips over when trying to fly?
This would be clockwise and/or counter clockwise propellers on the wrong motor(s). For copters with an even number of propellers, each propeller turns the opposite direction from the ones on either side of it. The reason for this is so the combined engine torque is in equilibrium. Unbalancing this equilibrium is what allows the craft to turn left or right without a rudder or tail rotor.
Regardless of spin direction all propellers must blow air downwards.
Hi my syma quadcopter x1 is stuck in the eversion how can i fix this ?? Thanks
1helpful
I have a 2wire HG-B modem/router and I want to extend my wireless network by using a Hawking HWRN1A router. How do I configure my 2wire with my Hawking router, so it can work?
this hint is only possible if your hawking can be used a an access poit. if yes then try try the following:
connect you adsl line into your modem/router,
connect the lan cable of your modem into a switch
connect both your PC and Hawking into the switch
have your modem/router provide DHCP and DNS
configure your PC to gte its ip address and DNS dynamically
configure your hawking access point to also get its dns and dhcp dynamically (do this by getting into the hawking http page configuration, or telnet if you are good with commands)
now set a wireless lan with WPA or higher through your hawking.
there you have it.
doubts??? i have more solutions
3helpful
2answers
Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
[email protected]
www.electra-craft.com
Hawking switch
The switch itself plays no role in an IP address conflict. PC's that plug in the switch should have unique or auto assigned addresses. Please try adjusting one of the PC's reporting the conflict.
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
Aron
Tom Chichester
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
