Question about OKI Office Equipment & Supplies
Oki data c9500 belt always dirty
Paper transfer print always print dirty
Posted by Caroll Garrick on
Victorman
  • OKI Master
  • 846 Answers
You will find the waste toner auger (Coiled wire in the plastic tube) is either snapped or blocked with hard toner. Its simple to remove as it just unscrews. If I remember correctly it sits under the transfer belt and runs down the back and right side of the base. Anyway clean and inspect it as that is what removes the waste toner.
Posted on Jun 22, 2018
5 Related Answers
Anonymous
  • 161 Answers
SOURCE: Oki C9500 makes VERY LOUD clunking noises but prints fine...
The sound is most probably from one (or more) of the drum units. You can check by taking them out and trying to run the visible gears by hand. If you have spare drums, change them one at a time until you find the defective one.
Posted on Sep 26, 2007
Anonymous
  • 32 Answers
SOURCE: Oki C9500 Printing Problem
Check the LED Head and LED Connection. The LED heads are interchangeable, BLK, Cyan, Magenta, Yellow.
Posted on Feb 15, 2008
Anonymous
SOURCE: Color registration problem for Oki Data C9500
Brain-storm .... simple solution .... REPLACED Magenta Drum.... works as good as usual, but is still and always been out a little - very strange, depending on the stock, if I'm using a 10pt coated stock, color registration has always been a little out ( when the cyan and magenta are being used ((together)) - purple - dark blue etc ...)
Posted on Mar 31, 2008
turk6459
  • 24 Answers
SOURCE: Oki C5500 printer keeps jamming
Open the tray and find yout imput roller. You can remove this roller and put it back on the other side. Normally this is caused because it is worn. The inside of the roller is like a new one.
Posted on Jan 24, 2010
Anonymous
SOURCE: I have a Oki C9500 laser, the magenta print is streaky
I have the same problem with my OKI c3100, please help
Posted on Apr 29, 2010
Oki data c9500 job offset home error
Where the paper exits the printer you will see 3 black sensor arms hanging down. 1 is the exit sensor and the other 2 are job offset sensors. On of those 2 will be stuck. Just gently free it and all should be well.
Jul 16, 2017 | OKI Office Equipment & Supplies
Where does oki c9500 waste toner box located
Your printer does not have a waste toner bottle. Waste toner is stored within the transfer belt. When full it will give you an error indicating its time for a new transfer belt.
Jul 08, 2017 | OKI Office Equipment & Supplies
My OKidata c9500 makes a loud clicking sound when I try to print. Like a drum turning and maybe the contact is not
Similar problem in other Oki's
It's not a drum, I would check the ITB Belt. Known for binding failure.
Okidata didn't spend a whole lot of money/quality plastic/nylon bushings and parts associated with the drive roller and other associated part for their ITB Belt assembly.
I hope this helps,,,Steve
Oct 12, 2014 | Oki Electric Industry Okidata Corporation...
Jan 13, 2010 | OKI C9500dxn Led Printer
Oki C3100 - v poor print quality
Hi Errol
The way to identifiy your problem is to send a full colour print to your printer and open the top just as the paper starts to come out . if you then remove your toner / drums for all the colours you can see the transfer belt if the quality of the image that you can see on the transfer belt is good and clear your problem is with the transfer form the tranferbelt to the paper and not any toner /drum issue and the most likley cause is the transfer belt itself "but before you relpace it remove it and clean around the electrical contact points and generally make sure the internals of the printer is free of loose toner .
Regards Alan (Alstech)
May 13, 2009 | OKI C3100 Led Printer
Mar 31, 2008 | Computers & Internet
Feb 15, 2008 | OKI C9500dxn Led Printer
Sep 04, 2007 | OKI C9500dxn Led Printer
71 people viewed this question
Top OKI Office Equipment & Supplies Experts
Thomas F. Schneider
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
