SOURCE: Water not circulaing through radiator, suspect
If water is not circulating through the radiator, the problem is more likely the water pump. Look and see if the water pump has any coolant leaking from it's vent or weep hole. If so, then the water pump is bad. As for the thermostat, follow the upper radiator hose to where it hooks on the engine. The thermostat should be located inside the housing that the hose hooks onto. Hope this helped and best wishes.
Please repost this in the appliance area dealing with this type of equipment as for some reason it is posted in the TV area.
SOURCE: Magic Chef mini frig freezing everything.
The thermostat is part of the temperature control found on page 6 here=> MCBR445S1_Parts_List Parts can be found here=> MCBR445S Parts If you have questions please let me know, Thanks Sea Breeze
RF-7350-59 Temperature Control Thermostat
