Question about HP Televison & Video
Would like to record from vip 612 to HP laptop
Posted by David Cloyd on
5 Related Answers
Jim Franks
  • 374 Answers
SOURCE: Dish VIP 612 breaks up when playing back recorded shows.
Edy, I am not going to say that this is the definite issue but Dish only has receivers that are 1080i compatible at the time which will give you some blurring and possible pixellating. 1080p will resolve these issues in the future. Therefore if you still need help let me know.
Posted on Mar 03, 2009
SOURCE: My ViP 612 keeps changing the channel on me and
Hi! I will be glad to assist you. Let try to isolate the problem 1st. your channel keeps on changing by itself with out touching the buttons on the remote. Okay, please go to the front panel of your receiver, open the fron t panel right door and push the sysinfo button, it will show the system information screen, check you remote address, ex 1 , lest change the remote address of your remote. how to: press and hold the sat button on the remote until all lights lit on the top, once it all lit, release it and press 9 on the remote, then press the pound button (#) that is under number 9, once you press the pound button, the sat button will flash 3 times then press the record button. you will see that the remote address is change from 1 to 9.. then select done on the screen. then it will go back to your tv show, check if the problem still exist.. if the the probelm still exist.. press the power button on the fron tpanel of the receiver for 10sec then release, after that the receiver will reboot by itsel and you will see attention 015, let the progress finish until it download the programming guide. once you got the tv show again check if the problem still doing , like changing the channels, deleteing the recording and skipping and rewinding.. if the problem still exist, pls call 1-800-333-3474 and talk to dish tech support, you have a dvr lost of function and the box needs to be replace. if you have any query pls get in touch..
Posted on Sep 20, 2009
Anonymous
  • 56 Answers
SOURCE: Need to Frequently Reset Dish Network HD VIP 612 Solo DVR.
When you bring up your guide look at the top of the screen and you will see the LIST: if this says ALL HD then press the guide button until you see ALL SUB or a menu and select ALL SUB. If your guide keeps changing by itself its possible to have remote interfence since you have a UHF remote, especially if you also see channel changes as well. Try setting the guide and go from there. If you still continue to have issues call 1-800-333-3474 for tech support for extensive troubleshooting or at dishnetwork .com/tech.
Posted on Dec 02, 2009
BeckiB_DISH
Becki Barned
  • 286 Answers
SOURCE: I want to connect dvd
Hey! This is Becki Barned, with Dish Network customer service!!! You may have already gotten this taken care of, but either way, here are some steps if you still need some help! How I imagine you have this set up, is that you have RCA cables going from the receiver to the main tv. In this case, you will want to take the RCA cables from the receiver to the DVD recorder to a port that says IN. Then you will want to have either coax or RCA going from the DVD from a port that says OUT to the tv. If you use coax, the tv needs to be on channel 3/4, and the DVD on an input. If you use RCAs, the tv will also need to be on an input, such as video 1 or 2. Good luck! Blog back if any troubles!! :) Happy troubleshooting!!!!
Posted on Dec 24, 2010
raycalo
Ray Calo
  • 358 Answers
SOURCE: ViP 612: i need the code for the dvr vip612...
Guest
You didn't specify the code you need, for TV or another component, so I am providing a link for the codes that will provide information for different TV manufacturers, DVD players, amplifiers, etc. You can look for your brand for the correct code. A have also provided instructions on programming the remote to this component. I hope this helps.
Program to TV:
Remotes: Basic (Television Only)
  1. Turn the Television On
  2. Press and Hold the TV Power button for three seconds until the LED flashes
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Link for codes:
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
Ray Calo
DISH Network
Posted on Jan 22, 2011
Getting error 311 message Reference Oecc I have a VIP 612 receiver, unable to record
The 311 message means the HD is going bad. You will need a replacement receiver. Have you unplugged the receiver from the electrical outlet for 10 seconds and plugged back in? If you still can't record, please call 1-800-333-3474 to order a replacement.
Aug 10, 2011 | DISH Network 311 DTV Receiver
Tip
DISH Solo VIP612 DVR Quick Reference Download
Download DISH Solo VIP612 DVR Quick Reference Guide
Would you like to review the features of the DISH Solo DVR VIP612?
Have you lost your DISH Solo DVR VIP 612 Quick Reference Manual?
Would you like a digital, searchable, pdf version of the DISH Solo DVR VIP 612 Quick Reference Guide?
Follow this link (& click FREE) to download a pdf version of the DISH Solo DVR VIP 612 Quick Reference documentation.
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 04, 2010 | DISH Network ViP 612
Tip
DISH Solo VIP612 DVR Manual Download
Download DISH Solo DVR VIP612 Manual
Would you like to review the features of the DISH Solo DVR VIP612 ?
Have you lost your DISH Solo DVR VIP 612 Owners Manual?
Would you like a digital, searchable, pdf version of the DISH Solo DVR VIP612 Users Guide?
Follow this link (& click FREE) to download a pdf version of the DISH Solo VIP DVR 612 documentation.
I hope that helps.
____________________________________________________________________
ViP 612 DVR hard drive is always running. I don't beleive it did this when it was new. At least I never heard it. It's about 2 years old. It is not the fan. The unit vents are clear. Tried reboot. No...
The function is always in use because of the ability to pause live tv and rewind. So its very common for the hard drive and fan to run often on DVR receivers. Does it still allow you to record programs? The best option would be to unplug it for 10-15 seconds which sounds like you have done. If the sound is becoming overbearing we can send a replacement receiver.
Nick Franta
DISH Network Customer Service
Jan 23, 2011 | DISH Network ViP 612
My dish network receiver vip 612 push to open door won't stay closed?
Hi, Mary with Dish Network Customer Service. I am sorry you are having a problem with the door on your 612 receiver box. The only to resolve this is to exchange out the receiver box for a cosmetic issue. They will send a new receiver and you can return that one. Please let us know if you have any other questions.
Jan 18, 2011 | DISH Network ViP 612
I want to connect dvd recorder to dish network solo dvr vip 612 that is split for two tvs.
Aug 20, 2010 | DISH Network ViP 612
Satellite Receiver to Yamaha Receiver
It sounds like either on the 612 or the Yamaha Receiver that the HDMI port is faulty, thus causing the flashing picture. It sounds like the 612 to the TV works fine. I would recommend replacing the Yamaha, and if problem persists then try replacing the 612.
Mar 18, 2010 | DISH Network ViP 612
When setting the timer frequency to ''Weekly'' on a ViP 612 Receiver, how many weeks does it record at that hour?
Indefinitely until it is discontinued manually. Or the program no longer comes on at that time. Thanks for using Fix Ya.
Feb 08, 2010 | DISH Network ViP 612
My Vip 612, when recording more than one channel and viewing either of these channels the screen pops up loss of signal. It doesen't return untill I unplug the unit for a few seconds. Upon repowering the...
I would call for a technician to come out as it appears the receiver may have been incorrectly set up or is malfunctioning. I suspect that you have a Dish Pro LNB and are using one line into the 612 which uses DPP technology. The short of it is the two are only compatible if two lines are ran to the receiver and the seperator is eliminated. Without being there to test the system end to end it is all speculation. Thanks for using Fix Ya.
Sep 26, 2009 | DISH Network ViP 612
Feb 21, 2009 | DISH Network DVR-625 DTV Receiver /...
Televison & Video Logo
Top HP Televison & Video Experts
RockTheHood
Stan Ford
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
