Oil level is OK, fuel ok, problems appears to be ignition with plug tester lighting up only occasionally. Is replacement of TDI feasible
My friend is a part time mechanic he gets his solutions from www.reliable-store.com he gets from their every single detailed info, instructions, diagrams etc. on all vehicles, and manuals like service, repairs, parts, owner's, operations, maintenance etc.
U can get help from there
there is a girl at chat she can help you
SOURCE: low oil warning light staying on oil level ok
would be best to have oil pressure checked with a mechanical gauge to be sure you have oil pressure.
hopefully you just have a bad oil pressure switch this is located on oil filter adapter rt above filter
SOURCE: vw polo 1.4 1999 oil light comes on at 3000 revs
Had exactly the same problem, completely baffled us until we discovered that the it was the oil pressure switch. We had already replaced it with a new one and then that didnt fix it so we fitted a new oil pump, but as soon as it was revved over 3000 revs the oil light came on. It turns out that there is actually a choice of 2 oil pressure switches for this car (1999 1.4 polo) one works only low pressure (black cap) and is the wrong one, the other works on a higher racio (green cap) its the high pressure one you need. If the oil light was on at tick over or below 3000 revs then its the lower oil pressure switch needed, above 3000 its the higher one. The parts people insisted there was only one, but there is definately a choice of 2 and it fixed ours instantly.
If it was an older model they actually have 2 switches on the car itself and one is a high pressure and one is a low pressure (just incase anyone needed to know)
SOURCE: VW passat coolant warning light on
There's a level sensor plugged into the bottom of the coolant reservoir. Unplug it and clean the contacts with electrical contact cleaner. If that doesn't do the trick, replace the sensor.
SOURCE: 1993 toyota corolla, problem no spark to spark
Check the ignition relay and all the main relays on the battery.
SOURCE: 2006 Subaru Outback: all of a sudden, the cruis
Hello, whenever the check engine light comes on the cruse light will flash as well, that is normal. The check engine light will not come on if fluid levels are low or if the temp is getting to high, I am pleased to know that you checked all of the fluids, most wouldn't have even the slightest thought to even try checking them. The On Board Diagnostics or OBD-2 for short only sets a check engine light when the ECM or Electronic Control Module reads a sensor value either too high or too low, but it has to read that same fault 3 consecutive times in a row to turn on the check engine light (w/ flashing cruise). Otherwise your check engine light would be going on and off all the time. I would go to your local parts store and have them check the codes for free because a dealer will have to charge you labor for them to check due to the knowledge needed to use the highly sophisticated scan tool they use. That way you can go either to an independent shop or a dealer with what the other scanner says is wrong which cuts down on the cost of repairs. They will probably ask you if you fueled up just before the engine light came on, in which that would be code P0440:EVAP leak(very small leak), that means the fuel tank sensor doesn't like how you put the fuel cap on. Subaru recommends AT LEAST 3 clicks when tightening your fuel cap. But until that code is checked you won't know whats wrong, if nothing went boom or bang you'll probably be ok. If it does end up being a fuel cap leak, then just loosen the cap put it back on and just make 1 full revolution, and just keep driving it. The light will go off within 3 full warm up cool down cycles or (drive cycles). I hope this info helps...(subyguru)...
