Question about Pentax Cameras
My Pentax k50 only takes good pictures when using the live view (monitor) When using the viewfinder, all pictures are dark. What is the problem?
Posted by Darin on
5 Related Answers
Anonymous
  • 2985 Answers
SOURCE: is my canon eos 400d broken?
This is a Digital SLR With SLR cameras you can only use the viewfinder because the image comesi nto the lens and up to the viewfinder via a mirror. When to take a pic the mirror flips up[usually with a crash] and the image goes to the CCD- afterwards you will get an image briefly in the LCD.
Posted on Sep 20, 2007
Anonymous
SOURCE: Subject too dark in viewfinder
It sounds like the infamous aperture control problem. I had mine fixed by this place:
http://www.garryscamera.com/
They had it for a couple of weeks, and when I got it back it worked perfectly.
Posted on Apr 16, 2008
t00nz
CameraR
  • 4738 Answers
SOURCE: Dark fuzzy/flickering screen - Cannon PowerShot A75
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Jan 26, 2009
SGNath
Sujith Gopinath
  • 170 Answers
SOURCE: my d40 has a image in viewfinder, will not take picture.
What lens are you using with the D40? Is it an AF-S lens? And is the Mirror Lockup on? Chech the Custom Settings menu. If mirror lockup is on, turn it off.
Posted on Feb 14, 2009
Anonymous
  • 148 Answers
It sounds to me that you are using an incompatible lens or a broken one. Does this happen with the lens that came with the camera?
Posted on Apr 02, 2009
My nikon D5000 monitor is dark and i have to look through the viewfinder to see the scene i want to take a picture of. monitor works fine to view taken pictures and in filming mode. why? and how can it be...
The Nikon D5000 must be set in "Live View" mode before you can use the rear monitor to take photos. There is a button that says "LV" to the right of the LCD screen that sets Live View to on or off.
Mar 09, 2011 | Nikon D5000 Digital Camera with 18-105mm...
Why can't i see what i am taking a picture of by the lcd screen?
That feature is called "Live View". The K100D camera does not support that feature.
More specification information can be found here
Regards,
Jacob
Mar 01, 2011 | Pentax K100D Digital Camera
My Nikon D60 monitor is dark...no image preview, however, playback for viewing pictures taken works fine. I use the viewfinder for taking pictures, but wonder if I've done something to turn off the monitor...
No, you have done nothing wrong. The D60 does not have the preview function on the monitor like the compact digital cameras. Nikon gave that function a name. It is called 'Live View'. The newr models like the D90 do have that feature. You can read further about your D60 here: www.digitalcamera-hq.com
Jan 06, 2010 | Nikon D60 Digital Camera
Nikon d60 does not allow me to view image whilst taking a picture
The D60 does not have a Live View capability. The monitor is used for shooting info, menus, and image reviews. It cannot be used to display the image while shooting. You must use the viewfinder for that, unless you connect the camera to a computer using the Camera Control Pro software from Nikon.
Jan 03, 2010 | Nikon Cameras
When the camera is turned on view window is not lit up viewing is dark and grey hard to focus but still takes a good picture?
Do you mean the viewfinder or the lcd-screen?
The Nikon D80 does not have a 'live-view' mode to watch the picture you're about to take on the LCD-screen. It's a semi-professional camera not to be used like a standard 'point-and-shoot' digital camera.
If it is the viewfinder that's out of focus, try adjusting the dial to the right of the viewfinder. It might also be that your internal mirror doesn't get powered (in this case you're unable to see the focus areas). In the last case you will have to get the camera serviced by Nikon.
Dec 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
The Monitor on my Nikon D80 does not show any image when I try to take a picture - The viewfinder is ok and the camera takes a picture ok and displays it for about 4 seconds on the monitor after taking it....
You can switch it off so as not to show the picture after you take one.
You cannot use the monitor to show images as you're taking them. The D80 does not have a Live View capability.
Sep 19, 2008 | Nikon Cameras
Nikon d60
The shutter remains closed on a DSLR until you take a picture. There is no way to preview an image that does not exist yet.
Being stuck with the tiny viewfinder as earlier cameras had is a good thing. Holding a camera out from your body will give mixed results due to your movements. You will get better results with the traditional method
Jun 28, 2008 | Nikon D50 Digital Camera
No pic framing on LCD display - playback is OK
ON digital slr cameras there is no pic framing on the LCD display.
Apr 25, 2008 | Pentax K100D Digital Camera
Pentax K100D DSLR
The interface IC ( between the main CPU and the CCD sensor ) seems faulty . Camera should go to the Pentax agents unfortunately.
Sep 02, 2007 | Pentax K100D Digital Camera
Cameras Logo
Top Pentax Cameras Experts
halotheracer
halotheracer
Steven Wander
Steven Wander
Mat Kramer
Mat Kramer
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
