Question about Kwikset Locks & Locksmithing
I purchased the Kwikset re-key kit and I screwed up the sequence of the rekey and now the key wont turn,neither the old key or the new key..how can I fix it?
Posted by Jilda Hilda on
5 Related Answers
Anonymous
  • 10 Answers
SOURCE: Lost entry door key, need to rekey kwikset deadbolt
Unfortunatley you need to have the key to remove the cylinder. You can take it to a locksmith that can pick" it to remove the cylinder and make you a key but it may be more cost effective to replace it.
Sorry not to be mre help.
Posted on May 22, 2009
Anonymous
SOURCE: I bought 2 kwikset deadbolts.The first one worked
put the 'dummy key' that came in with it, turn it a 1/4 turn right, put smart key in, pull out smart key. pull out the key and insert the key that you would have as a desired key and turn left 1/4. thats it!!!!!!
Posted on Jul 20, 2009
Anonymous
SOURCE: kwikset smart key has no key. need to rekey. how
Here is the instructions from kwiksets website
http://www.kwikset.com/Files/PDF/SmartSeries/SmartKeyInsEnglishOnly.pdf
Posted on Oct 21, 2009
Anonymous
SOURCE: I have a kwikset smart key and after I rekeyed the
Call the 800 number for Kwikset and they will send you a replacement but only the inside lock. That's the only solution to your problem.
Posted on Feb 20, 2010
Anonymous
SOURCE: we tried to rekey our kwikset smart key, but
I had mine do the same thing right before I was leaving to the airport [re-keying for the house-sitter]. I was setting the lock and I hear a spring-type ping and the keying was lost.
The tumbler can be reset to your key. However, it involves disassembling the device and has small parts.If you are feeling lucky, you can do this yourself or take it to a qualified person.
If you are feeling lucky:
A: Disassemble the lock from the door
B: Remove the door handle from around the key side.
C: Remove the U retaining-clip from the outside of the lock that is securing it to the shaft.
D: Remove the lock from the shaft
E: Remove the U retaining-clip from the tumbler body and the case
F: You will have to press the five fingers down evenly on the length of the case to slide the cylinder out of the case. (I cut a plastic card with small wire cutters to make a tool, but you could probably use thick card-stock and some scissors.)
Be careful; you will have to watch for and secure the check ball on one side of the tumbler and the finger lock bar on the other side as you slide this out.
G: Remove and store the check ball securely as well as the finger lock bar. (careful with the plate surrounding the fingers that the finger lock bar resides in)
H: Remove the finger locking plate. Carefully, make sure the fingers are still inside and oriented correctly and the spring at the back of the finger locking plate is left in place.
I: You will notice a u channel groove in the fingers and the finger locking plate. Align the fingers in the finger locking plate evenly so that the grooves in the fingers match the groove in the finger locking plate.
J: Replace the finger locking plate with fingers aligned evenly with the u channel groove back onto the tumbler body and hold back against the spring left on the rear of the tumbler body. This puts the tumbler into re-key position.
K: Replace the finger locking bar onto the finger locking plate while holding the assembly against the spring and tumbler body. (If this is done correctly, the finger locking bar will now be flush with the side of the finger locking plate and not raised as normal.)
L: While holding the tumbler assembly together and maintaining the locking plate pressed against the spring, Insert your new key into the tumbler body.
M: While holding this assembly in this position, add the check ball to the tumbler assembly.
N: While holding the assembly in position, slightly depress the black plastic block at the back of the finger locking plate and slide this tumbler assembly back into the tumbler case taking care to rotate the case 90 degrees clockwise from normal. (Note the U channel groove inside the tumbler case that normally receives the finger lock bar and use that for orientation.)
If the tumbler does not insert cleanly, verify the finger locking bar is flush. If it is not, redo while maintaining proper pressure to keep the finger locking plate firmly against the spring in re-assembly. Also, verify the fingers are not protruding from the tumbler body. If they are, redo the procedure taking care to align the fingers properly on assembly and maintain proper force on the finger locking plate against the tumbler body during re-assembly and new key insertion
O: Rotate the key and tumbler body in the case to the normal position (counter-clockwise 90 degrees).
P: While holding the tumbler body firmly against the case, remove the key.
Q: Re-insert the key and verify smooth rotation.
R: Align the tumbler body and case back to the normal position and while holding the tumbler body firmly against the case, remove the key.
S: Replace the U retaining-clip that belongs on the back of the tumbler body to secure it within the case.
T: Replace the tumbler body in the main lock shaft and secure with the shaft U retaining clip.
Posted on Nov 12, 2010
No key for a schlage dead bolt i like to rekay
If you don't know how to open a lock cylinder in your hand, you probably should take it to a professional locksmith. They don't charge much to rekey a lock that you bring into the shop, and they can usually do it in under ten minutes. Twelve minutes if you don't bring a key that can open it.
That said, you can open it by shimming with a key blank and a shim, bumping with a bump key, removing the slide or top of the cylinder, picking with a pick, pick gun, or electric pick, key picking it, using tryout keys, rapping it open with a hammer handle, or simply wiggling every old key you can find in it until it either turns or you run out of old keys.
Dec 20, 2013 | Kwikset Professional Door Lock...
Kwickset door handle fell apart on my front door help
Kwikset locks are inexpensive because they do not have replaceable parts. Buy a new one.
By the time the lock breaks, it's probably time to get different keys, but if you have so many keys in the hands of people you cannot contact, or you have more than three other locks keyed alike, and you must have the new lock work with the same keys as before, the place where you buy new locks probably has someone who can rekey the new lock to your old keys. Kwikset also sells locks that you can rekey to other Kwikset keys yourself. They are more expensive than other locks of the same type, but could save money long term, especially if you find a need to rekey your locks a lot (lots of visitors, part-time tenants or roommates, your kids lose their keys a lot, etc.)
Sep 07, 2013 | Kwikset Professional Door Lock...
How do I rekey smartkey when original keys are lost?
the only way to fit a new key to the ' smartkey ' lock system is to use the Kwikset smartkey reset tool, then after the cylinder is reset - you can put a new key in it for alignment.
this tool is availible at most lockshops and they will reset the lock for about 5 dollars.
c...
Jan 14, 2011 | Kwikset Professional Door Lock...
Kwikset SmartKey Error in Changing Key to Lock
Your out of luck this new design is terrible once it locks up and no keys turn it, the lock is done you will have to replace it use the traditional pin tumbler style kwikset and it can be rekeyed unlimited times by a locksmith with or without a key.
Apr 22, 2010 | Kwikset Professional Door Lock...
Just had my kwikset dead bolt lock rekeyed. i put it back on the door and now you can't pull the key out after you lock the door. please help
Sounds like its binding. Loosen the screws that hold the 2 halfs together. Get the key to work smothly. snug the screws and try again. If ok then tighten the rest of the way.
Sep 24, 2009 | Kwikset Locks & Locksmithing
How do i rotate the kwikset cylinder 180?
try this powerpoint video I made and uploaded to youtube. It is quite primitive but if you can pause and read it at each step it may help. This was for the kwikset lever entry lock. Thanks,
Jul 30, 2009 | Kwikset Professional Door Lock...
I bought 2 kwikset deadbolts.The first one worked out fine.The second one I turn the original key by accident.Now neither key will work.Is there a way to rekey my original key.
Jul 20, 2009 | Kwikset Locks & Locksmithing
I cannot remove the door lock to replace it.  It is a screwless type but i dont know the brand
generally, you remove the faceplate on the thin side of the door... there should be 2 screws there... then you'll see 2 holes on another faceplate underneath that one, which require an allen key of the right size... if your lucky you'll see a flathead bolt that can be loosened... then put your key only partially into the deadbolt and turn it counterclockwise and it will come out into your hand... then replace it or rekey it.
Jan 13, 2009 | Kwikset Professional Door Lock...
Lost keys to my Entry door lock
Visit your local Home Depot and purchase a Kwikset re-keying kit. They're inexpensive and work fine but stay alert and follow the instructions properly. This kit comes complete with proper pins as well as new keys. Good Luck!
Mar 07, 2008 | Kwikset Professional Door Lock...
Locks & Locksmithing Logo
545 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Marvin
Marvin
john h
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
