SOURCE: Video Downloads and Webcam do not show in color...Only Black and white
There is an option in the Webcam properties for black and white.
1. Open the Webcam program.
2. Top right corner of the window click the "down arrow" button next to the minimize and maximize button.
3. Select "Properties"
4. On the right side of the window, under the heading "Extra Control", make sure there is no check in the box.
Hope this helps.
SOURCE: MSI starcam 370i only shows black and white
You can change your lighting to fluorescent lighting the brighter the fluorescent lights are the better your cam will show up the colours, it worked for me.
SOURCE: DVR playback in color on TV 2 playback in black and white on TV 1
This is a receiver issue and will need to be replaced as the internal hardrive has an issue that cannot be resolved onsite by a technician. Thanks for using Fix Ya.
SOURCE: show movies in black and white no color
unit is in a progresive mode. need to turn back to interlaced.
SOURCE: my tv only shows black and white no color, how do
You should check circuit boards for bad solder joints. It's possible to have a defective part on the board, open resistors, coil with broken wire or others. You could have a defective chroma chip or joint/part in the area. You should check the tv menu to make sure the color settings haven't been turned down first.
