Question about Firearms
L C Smith dbl SXS 16 field grade shot gun. Left barrel says Hunter Arms Co. Inc. Mfrs Fulton NY USA. Back of barrels and on action are #'s FW 101398. Trying to determine age and value?
Posted by John Buccos on
Jean DeLauche
  • 2,911 Answers
Hello, John -
If you have not yet discovered the L. C. Smith Collectors Association web site, then this is the link to the association home page:
http://www.lcsmith.org/index.html
Reading the association's article here may prove instructive about your shotgun:
http://www.lcsmith.org/shotguns/1913grades.html
On the association home page, in the left side bar, scroll down to the link for Shotguns. Through that link you will find a link for Year of Manufacture. Click or tap on that link.
On the web page for Year of Manufacture, near the bottom, you will find this sentence:
(Quote)
To obtain all of the existing information about your shotgun, the Research Division of the L.C. Smith Collectors Association can search the factory production records and can provide this information in a letter.
(End quote)
http://www.lcsca.clubexpress.com/
There is a charge for such research, however.
Best wishes.
Posted on Mar 19, 2018
4 Related Answers
HondaCRX
Dan Martin
  • 252 Answers
SOURCE: browning shotgun sweet sixteen age and value
In general, a 1950s Sweet Sixteen is a valuable gun. Measure the distance from the trigger to the end of the **** stock to get the "legnth of pull" (LOP). this was 14 1/14 " when it left the factory. If it is shorter, the value will be less.
Without seeing it, although many have been altered which would bring a price $350 - $450 area.
This guide might help if you can determine the condition : OS is 1958.
AUTO-5 SWEET 16
- 16 ga., 2 9/16 in. chamber from 1937-1940, and 2 3/4 in. chamber from 1947-1975, similar configuration to Lightweight, 12 and 20 ga., gold plated trigger, 10 oz. lighter than Standardweight Model 16 ga., 1937-1940 mfg. Sweet Sixteens were available in pre-war Grades I, III, and IV. Mfg. 1937-1975 by F.N.
Grading ...............98% ....95% ....90% ........80% ........70%
Plain Barrel .......$950 ...$825 .......$725...... $625 .......$500
Solid Matte Rib $1,300 .$1,075 ....$950 .......$825 .......$700
Vent. Rib .........$2,100 .$1,650 .....$1,225 ...$1,050 ....$875
Subtract 20% for front safety.
Subtract 20% for 2 9/16 in. chamber.
Posted on Jun 25, 2010
Matthew Kurtz
  • 4 Answers
SOURCE: Pump Lever Hangs Down
My advice is to search every were till you csan find that exact model and then ask the owner what theres looks like
Posted on Jan 06, 2013
Tim Janzer
  • 74 Answers
SOURCE: How can i find out what length of a shells are ok to use in my Harrington & Richardson arms co. Worcester Mass. U.S.A single shot 410 ga. shot gun
It should be stamped on the barrel. If not, please take it to a gunsmith. He should be able to tell you what lenght of shell can be safely fired from the gun.
Posted on Nov 09, 2014
JBnID
JBnID
  • 243 Answers
SOURCE: I bought an Iver Johnson single barrel 12 guage shot gun. Can anyone tell me about this gun?
It was built on the 1890 Hopkins and Allen patent and is very similar to several dozens of inexpensive single shot shotguns.
Posted on Dec 03, 2014
I have an Iver Johnson Cadet Model: 55S-A. 32 cal. 2 1/2 in BBL. 5 shots Serial No B27690. I would like to know more about the gun.
The Iver Johnson Cadet was offered as (the basic gun) as the Model 55 Target, and the 55A then the 55S Cadet and the 55S-A Cadet. The "parent" is discribed as: IVER JOHNSON MODEL 55 TARGET,Revolver,double-action,22LR,8-shot,4 1/2",6" bbls and 10 3/4"(6") 9 1/4"(4 1/2") over all length weight 24 oz.(4 1/2") 26os(6"); large frame,pull pin cylinder release with flash control front rim; recessed cylinder chambers;fixed sights,oversized molded one piece Tenite plastic target type grips; Does not have the "hammer the Hammer'action,matte blue finish; After 1958 cylinder is fluted hard chrome lined barrel introduced in 1955; dropped from production in 1979..the .38 caliber offering is designated as the Model 55S-A which is the same as the above except that: it was offered in .22LR,.32 S&W and .38 S&W(this is NOT a .38S&W Special) and as an 8-shot in .22, as a 5-shot in both .32 and .38. it is 7 1/2" oal w/ loading gate on the Right side AFter 1974/1975 this model is called"I J Cadet it was introduced in 1961 and dropped in 1979 Values: Vgood=$110..Good=$85 and Fair=$75. This data is from the Gun Digest Book of Modern Gun Values and more detailed Iver Johnson histroy can be had from www.gunshowbooks.com..check out Bill Goforth's Iver Johnson Arms&Cycle Works Firearms 1871-1993..Bill also frequents these forums and he along with Jim Hauff will likely correct any misinformation I may heve relayed as well as correct any ommisions.
Oct 04, 2018 | Firearms
What is the value of 1920 O LC Smith 16 gauge double barrel field grade shotgun
Hello, Roger -
Fixya.com is a website intended for asking and answering questions on how to go about repairing things. Fixya.com is not a website which can provide valuation estimates for anything, except perhaps the cost of repairing some item.
I found the following information on the L.C. Smith Collectors Association website:
https://lcsca.clubexpress.com/content.aspx?page_id=274&club_id=43784
FAQs
General Information
How can I determine the value of my L.C. Smith?
(Quote)
Gun value is determined by grade and gauge rarity, amount of remaining original finishes, condition of mechanics and wood, and an intangible called "Collectability" (collectible gun values can vary upwards and downwards with demand fluctuations).
Another important factor impacting value is the "Historical Factor." In those rare instances, an otherwise low-grade and abused 1890 hammer gun, worth only the price of the nails used to hang it over the mantle, could be worth thousands of dollars if its provenance can be unquestionably connected to a colorful and legendary historical figure such as Doc Holliday or member of the Dalton gang; a famous show person or shooter such as Annie Oakley or Captain A.H. Bogardus; or a Hollywood actor such as Clark Gable or Humphrey Bogart.
Since it is impossible to accurately assess gun condition and originality, either by description or internet image postings, the L.C. Smith Collectors Association cannot, and does not provide estimates of gun value.
Possible sources for such value determinations include various internet auction sites, like GunBroker, Guns International, DoubleGunShop.com; and, outside the internet, The Blue Book of Gun Values, published each year and used by all gun dealers. Copies of this book are available in almost every gun shop and book store; and should also be available in your local library. Pay particular attention to the "condition" examples featured at the front portion of this book when evaluating your gun.
The Shotgun World website has a forum for questions regarding "Shotgun I.D. and Value".
http://www.shotgunworld.com/bbs/viewforum.php?f=5
http://www.shotgunworld.com/bbs/viewtopic.php?f=5&t=423424
Often, dealers who specialize in vintage double guns are willing to provide a written estimate of value for insurance purposes. When you ask a dealer to appraise your gun, understand what it is you want to know. If you tell the dealer you wish to sell the gun, you will receive a "wholesale" value. The dealer would be buying to resell, and the difference between his cost and the sales price is his profit. If you ask for a value for insurance purposes, you will receive a high valuation that is most likely more that the gun would bring on the open retail market; therefore the actual value of the gun lies somewhere between the wholesale and appraised value of the gun.
Also remember that "sentiment" is not a value factor; and therefore, never enters into any estimate of gun value. A part of family history is invaluable...to the family...but not to a purchaser of that "family treasure".
To better estimate/understand gun value, it is also helpful to visit large gun shows (like the Las Vegas Antique Arms Show or Wanamaker Gun Show in Tulsa), and note the prices of guns in similar condition and grade as yours.
Finally, please remember that "Knowledge Is Power", and the more research you do, the better you are prepared. Don't be timid about asking for information on the Forum; and additionally, we suggest you begin your research with a copy of John Houchins' in-depth work on the Smith gun, "L.C. Smith, The Legend Lives."
Warmest regards,
Drew Hause, Tom Archer, and Bill Hambidge
(End quote)
Best wishes.
Oct 03, 2018 | Firearms
How Do You Tighten The Barrel On A Model 49dl Marlin 22 Lr
A lot of times there is a hidden screw behind the back of the stock where your shoulder rests.. Be sure you don't have what they call a floating barrel. This style can not be tightened per say if what your calling a loose barrel is the rest under that style of barrel.
Apr 23, 2018 | Firearms
What does pd mean on a smith & wesson magnum 357
The PD series is Smith & Wesson's idea of a handgun that is lightweight enough to be always on hand when needed but it is not necessarily intended to be shot often. Carry ability and concealment are optimized while heft and shooting comfort are sacrificed.
"Personal Defense", PD as opposed to a gun that is mainly intended to be a range gun, showpiece or race gun (Performance Center, PC) or sidearm for military or police (M&P).
Apr 07, 2018 | Firearms
How do i remove stuck pellets in the barrel of my gamo c 15
Hello, William -
According to the instruction manual for the Gamo C-15 Blowback firearm, you could use ". . . a 4.5mm caliber cleaning rod (.177 in) if a BB has become blocked in the barrel."
The information regarding a blocked barrel is on Page 11 of the instruction manual in the REPAIRS section.
If you do not have the instruction manual, this is the link to the PDF document (Adobe Reader software needed - free):
TinyURL link:
https://tinyurl.com/y9zwcvtk
The information is on Image 6, right side, of the PDF document.
(Quote from the instruction manual):
Repairs
A compressed air p1st0l (have to spell it that way or the Fixya algorithm reads it as a "bad word") that is not functioning well can be dangerous. Do not attempt to repair the gun yourself, since this may cause abnormalities in its functioning. Use a 4.5mm caliber cleaning rod (.177 in) if a BB has become blocked in the barrel. Take your gun to approved gunsmiths or to professional repair specialists approved for this type of product.
(End quote)
Best wishes.
Feb 22, 2018 | Firearms
I am interested in old break barrel air gun in .25 cal, where can I find them
Hello, Ellis -
Air guns, used and new, are sold by firearms stores.
I have no idea where you reside, so I cannot even direct you to places in your area where firearms are sold legally.
Best wishes.
Feb 15, 2018 | Firearms
I have a small frame 7 shot 22 Cal. break top H&R revolver. I was told my grandfather carried it in WWI. Serial# 371177. I would like to know the manufacture date and if it was an Army issue.
James
Decoding H&R serial numbers is not easy and it takes up quite a bit of the H&R book as different models usually have seperate serial number series. gererally speaking there were three types of serial number series.
Pre 1905 (1904 and before) which were more like batch numbers and usually ran from 1 to 99,999. on some models there was a different series every year.
Post 1904 (1905 to 1939) one single series starting at 1 and going into the middle 6 digits (some third model auto-ejecting revolvers have been observed with number in the 800,000 range.
Ift here does not look like there are any markings on the left side of the barrel other than the caliber this would be the premier model fitted with extra cost oversize grips and 6 inch barrel. during the same time (1925-1934)frame H&R offered this revolver as the H&R TARGET (aka model 766) the only difference was H&R Target was marked on the barrel. by the time the premier model was fitted with a longer barrel and oversize grips the cost was about the same for the two models. the offering of the H&R Target model was just another way to try to sell more revolver. factory serial numbers are not available for this model so i believe this revolver was manufactured before the H&R Target was introduced in 1924 (most likely 1920 to 1923)
below is information of both models.
H&R PREMER SECOND MODEL SMALL FRAME TOP BREAK R.F. & C.F. ----------1905-1941
Small fame double action top break revolver with double top post barrel latch; calibers and cylinder capacity, 22 rimfire-7 rounds, 32 S&W, 5 rounds; automatic cylinder stop; standard finish Nickel with case harden hammer and barrel latch; standard barrel length 3 inches, with 2, 4, 5 and 6 inches available as optional; HAS CALIBER MARKINGS ON LEFT SIDE OF BARREL WAS MANUFACTURED FOR SMOKELESS POWDER CARTRIDGE PRESSURES.
There has not been enough data gathered on serial number to try to come up with a serial number range for the different variations.
First Variation, model name & caliber marked on left side of barrel, patent dates 5-14-89, 4-2-95, 4-7-96---------------1905-Only
Second Variation, model name & caliber marked on left side of barrel, patent dates 4-2-95, 4-7-96-------------------1906-1908
Third Variation, caliber only marked on left side of barrel, patent date 10-8-95-------1909-1913
Fourth Variation, caliber only marked on left side of barrel, no patent date, state not spelled out in address (MASS)---------1914-1915
Fifth Variation, caliber only marked on left side of barrel same as 4th except different font used in barrel markings----------1914-1915
Sixth Variation, caliber only marked on left side of barrel. State name in barrel marking spelled out (MASSACHUSETTS)-----1916-1924
Seventh Variation, new grip frame, there is no step down for the grip panels to fit into-----1925-1942
After 1930 listed in catalogs as; PREMIER No. 30 .22 Rimfire 7 shot & PREMIER No. 35.32 S&W 5 shot
VALUE: 100%=$265 60%=$75 Add 10% premium for blue finish; 20% premium 4", 5" or 6" barrel; 20% premium for 22 rimfire caliber; 10% premium for 7th variation
If this is a top break it is a H&R Premier model manufactured in the 1924 to 1930 era or one of its variations. if it is a solid frame model it is a model 1906 or one of its variations manufactured in the 1932 to 1937 era. without a picture or knowning the exact markings i can't give you an exact model.
1940 and after letter codes used to denote year of manufacture. starting with A in 1940 and going to BC in 1986.
Caliber markings on the side of the barrel ALWAYS indicate 1905 or after manufacture. when H&R made the switch to smokeless powder in 1905 they started marking the caliber on the left side of the barrel of all their handguns. no caliber markings = black powder, caliber markings = smokeless powder.
Please keep in mind that H&R did not always obey their own rules and there are exception to every rule. during 1890 though 1904 H&R was manufacturing so many top break revolvers they starting using a letter code after 100,000 had been reached. these letter code were stamped along with the serial number on the bottom of the top strap (the cylinder had to be removed to see this location).
Hammerless Bicycle models (1899-1920). the caliber markings and 6 digit serial number indicate it is a second model and if in good condition it should be safe with modern ammo. the bicycle hammerless (small frame, 2 inch barrel) is serial numbered in the same series as the regular small frame hammerless model.
Pete
Apr 11, 2017 | Firearms
Firearms Logo
162 people viewed this question
Top Firearms Experts
Marvin
Marvin
jws1013
john h
Are you a Firearm Expert? Answer questions, earn points and help others
