Question about Dual Audio Players & Recorders
Reset of clock on Dual car radio xd250 - Dual Audio Players & Recorders
Posted by carolyn carlson on
2 Related Answers
Anonymous
  • 814 Answers
SOURCE: need to reset dual alarm to wake up
http://www.emersonradio.com/owners/SmartSet%20Series/ Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson web page of the smartset clock/radios. Find you model number smartset clock/radio and open the link to download a pdf copy of the owners manual.You can use the print function on your computer to make a pdf copy of the owners manual for you own use. I hope this information helps you with your problem.
Posted on Jun 12, 2009
Anonymous
  • 65 Answers
SOURCE: sounds like it seizes, resets the clock
first start with the obvious...check the battery.if that is ok,then it is your starter that is drawing to much power when you try to start it.Starter will need to be replaced or repaired.
Posted on Jan 17, 2010
How do I trouble shoot my usb port?
Quote from the manual:
The USB port provides power only, and will not playback music from a USB device.
You can download the manual here:
http://www.dualav.com/support/manuals/xd250.pdf
May 07, 2014 | Dual XD250 CD Player with Auxiliary Input...
Cant find a harness to plug into the back of a Dual XD250 RADIO.
You won't ever. They make a universal harness. You should have a wire harness for your new radio only that was included with the radio. It should plug into the new radio and the other end will just be wires. Then you will need to go to a parts store, ( AutoZone, Oreilly's, Advance Auto, Etc) and but a radio wire harness for your truck. It will have a connector or two that plug into the harness that plugs into the back of your stock radio and the other end will be just wires. you will then connect the two harnesses together by matching wire color. ( EG: Purple to Purple, Gray with black stripe to Gray with black stripe, etc)
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Car Audio & Video
How do I dim the lights
Press and hold the Audio/Menu button for more then three seconds. This will take you to the setup menu. Press the Audio/Menu button to go thru each option. turn the dial to change the settings. Options in this menu are: USA or EU frequencies, Local or Distant tuning, Clock on or off while unit is off, Beep on button press, and finally, Backlight Hi or Low.
Feb 22, 2013 | Dual XD250 CD Player with Auxiliary Input...
Need to reset dual alarm to wake up
Apr 08, 2009 | Emerson Smartset Clock Radio
T301B Tme Zone
OK kalalist4,
You cand find the manuals for all Timex Clock/Radio conbinations at:
http://www.timexaudio.com/product_manuals.asp
Go Get 'Em
FixedThemAll.......
Oct 28, 2008 | Timex Auto-Set Dual Alarm Digital Clock...
Sony dual alarm am/fm alarm clock radio
HOW does one set the time and alarm on a "sony dream machine clock radio"?
Aug 28, 2008 | Sony Dual-Alarm AM/FM Clock Radio with...
Sony Liv Clock Radio, Cd Player
I have a sony dream machine ICF-C18 and had day light saving time and cannot change the time
Please help
Jun 17, 2008 | Sony Dual-Alarm AM/FM Clock Radio with...
144 people viewed this question
Top Dual Audio Players & Recorders Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
