Question about Westclox Audio Players & Recorders
SOURCE: TEAC SR-L100
Go to your nearest music store and purchase a red gel (used for illuminating the stage). Or any transparent red piece of plastic. You can trim it to about 4X4 and place it in from of the clock face. FYI the red color is used in aircraft to illuminate the instrument panel with the least effect on the retinas. I think it has to do with the wave length of the light or something like that.
RMR
Posted on Mar 01, 2008
SOURCE: Westclox Monarch Alarm Clock - Model No. 90003
While holding down the snooze bar that says "ALARM" on it, hold down either of the "HOUR" button to set the hour when the alarm should go off or hold down the "MINUTE" button to adjust the minutes for when the alarm should go off. Switch the "ALARM" to "ON" when done.
Posted on Sep 03, 2008
SOURCE: lights will not turn off, brights blue lite on all
Your turn signal/headlight multifunction switch has failed.
To replace it, remove the four screws from the bottom of the steering column cover, split the cover apart.
Unplug the one connector out of the bottom of the headlight switch, then depress the two levers, on top and bottom of the switch housing, and slide the switch out.
Install in reverse order.
Posted on Oct 27, 2009
SOURCE: I have a westclox atomic alarm clock - model #700...
I have the same alarm clock the damn thing gives me a heart attack when I wake up. All in all I have the instructions for your clock.
Simple on the back of the device there are five buttons hold down the one that is labeled mode/set then the display will flash use the oC|oF/Up key or Wave/Down key to change the keys and the mode/set the to move between each field.
If you press (not hold) the Mode/Set key you can change the alarm, change the numbers using the degreeC|DegreeF/Up or Wave/Down key to change numbers accordingly.
To turn the alram and snooze function on or off press the Alarm/on\off key.
What I just said may sound complicated but of you press the buttons as I told you then you should have no problems what so ever.
Posted on Jun 03, 2010
SOURCE: Westclox model 22717
Wesclox 22717 reset problem
Searched the web but couldn't find the answer either. I was about to throw the clock away when my 10 year old son came by and said "press hard". So that's the answer! I used a pen to press the time button then hit the hour and minute and it did the reset. Good luck.
Posted on Sep 23, 2011
