Question about Krups Coffee Makers & Espresso Machines
Krups XP 7200 series thermal block shots water after release of top filter
When machine finishes brewing cycle, it releases the top filter valve and the remain water keeps boiling and therefore it shots out water reseude with coffee if working fully to the interior of the machine, clogging up everything, as well the left over pads are very juicy and wet. What is wrong with the machine? what shall be replaced?
Posted by Ferenc FairCo on
Ross Keen
  • Krups Master
  • 1,364 Answers
Replace the valve on the distributor or if necessary the whole distributor. While you are at it replace the tamping piston seals and the barista seal.
Posted on Mar 22, 2018
5 Related Answers
Anonymous
SOURCE: leaks at the hot water spout during coffee brew
I had the same problem. I ended up taking the coffee machine apart and found that the reason coffee trickles out around the hot water spout is that the two coffee nozzles were partially plugged. Since I Had parts of the coffee machine apart I was able to clean it easily. It may also be possible to clean the assembly using a pick of some sort and clean out the holes of the two normal coffee spouts. Inside it is just a open cavity so gentle poking around and using some steaming hot water may do the trick.
If you want to take the machine apart you need to do the following: 1) take of the warmer plate on the top - 2 storz screws but an allen key works as well 2) take off the top plate of the machine - another 4 or 5 screws - make sure you empty the beans first otherwise you will have a mess 3) remove one screw from the right hand side of the removable coffee ground tray. Once this screw is removed the front panel is free to swing open except for the pipes connecting the front 4) unclip the steam assembly - there are a couple of plastic catches on the top. this will free the steam assembly from the front panel and also free a pipe connections. The steam dispenser pipe will also come free from the steam assembly. 5) remove the coffee pipes from the up and down sliding coffee dispenser. This is a small whitish color clip with 2 pipes connecting into it. The white clip has a little plastic catch on the top that frees it. The front panel should now swing open freely. 6) remove the sliding coffee dispenser from the front door. There are 4 plastic catches, 2 on either side. the whole front sliding coffee displenser now comes free 7) Take the sliding dispenser apart by release the 4 plastic catches on the front curved planel. 8) Inside the sliding dispenser is a white plastic piece that connected to the piping released in step 5. There is a small plastic catch that needs to be pressed while pulling fairly hard on the plastic piece and bending the whole piece. 9) You will now see the plugged spouts. It goes back together really easily.
Posted on Sep 15, 2008
Anonymous
SOURCE: Krups XP7240 leaks
The grind selector knob can be removed with the following steps: 1) Remove screw on side near grinder (do not let the screw fall into grinder, :-) ), 2) use sharp knife or similar to pry off cover with three dots. This should be easy. 3) Now you can rotate the grind selector and see that the white clear plastic does not rotate and the black does. There are two little pieces (one black, one clear plastic) on opposite side from grinder that slide over eavh other to keep this knob 'locked' into place. 4) again with a sharp pointed knife or similar you can separate these two pieces to 'unlock' them. This is made easier by lifting the side of the bean holder by the grinder gently and tipping it up. Be careful not to force anything too much. The black part should pop off. 5) Now you can lift off the clear bean holder.
After this good luck. We made it farther into the machine, but could never get to where we needed to go to fix our problem.
Krups must be congratulated for designing a machine that cannot be repaired and must be replaced with new purchases.
Posted on Jan 11, 2009
Mark Egan
  • 1214 Answers
SOURCE: Mr Coffee stopped brewing
Sounds like there are a couple of problems -
First, are you certain that the coffee basket is clean? If the coffee basket has a valve on the bottom that allows you to remove the carafe to pour a cup of coffee, make sure the valve is clean. Being dirty would cause it to trickle coffee slowly into the carafe, and will hold coffee in the basket too long.
2nd, you may need to flush the water heating system as they can become corroded with precipitated solids from the water.
To do this, mix 1 part vinegar to 2 parts water in the carafe. Pour into the coffee maker and tell it to make coffee. Do this a couple of times, using a fresh mix of vinegar and water each time. Pour the used mixture down the drain.
When you feel it is clean, follow it up with a fresh pot of water. Then wash and rinse the carafe.
The coffee maker is now ready for it's next use.
Posted on Jan 30, 2009
bansheracer
  • 1089 Answers
SOURCE: I have a Livia 90S - about 4 years old. Recently
HI When you back flush do you use a detergent for espresso machines? If you don't your 3 way valve might be stuck with coffee oil residue. You might also have a bad 3 way valve.
Posted on Jan 26, 2010
Testimonial: "This confirms what I needed to know. It was very helpful."
hsvgomez
  • 6 Answers
SOURCE: My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Posted on Dec 05, 2010
Adjust bunn coffee maker water level
To adjust the brew volume/batch size you will need to access the main circuit board behind the front panel. Isolate the machine before removing panels.
NOTE: Check that the brewer is connected to water supply, the tank is properly filled and a funnel and server or decanters are in place prior to setting or modifying batch sizes.
  1. Modifying batch sizes: To modify a batch volume, first check that the SET/LOCK switch is in the "SET" position on the circuit board. If the brewer has a batch selector switch, position it to the size to be changed. To increase a batch size: Press and hold the START or BREW switch until three clicks are heard. Release the switch (Failure to release the switch within 2 secs after the third click causes the volume setting to be aborted and previous volume setting will remain in memory) and press it again one or more times. Each time the switch is pressed, 2 secs are added to the brew time period. Allow the brew cycle to finish in order to verify that the desired volume has been achieved. To decrease a batch size: Press and release the START or BREW switch once for every 2 sec interval to be removed from the total brew time period; then immediately press and hold down the START or BREW switch until three clicks are heard. Release the switch. (Failure to release the switch within 2 secs after the third click causes the volume setting to be aborted and previous volume setting will remain in memory). Allow the brew cycle to finish in order to verify that the desired volume has been achieved.
  2. Setting batch sizes: To set a batch volume, first check that the SET/LOCK switch is in the "SET" position on the circuit board. Press and hold the START or BREW switch until three clicks are heard (this will take approx. 10 secs) and then release the switch. (Failure to release the switch within 2 secs after the third click causes the volume setting to be aborted and previous volume setting will remain in memory). View the level of the liquid being dispensed. When the desired level is reached, turn the ON/OFF switch to "OFF". The brewer remembers this volume and will continue to brew batches of this size until the volume setting procedure is repeated. Empty server(s), turn selector switch to positions that have yet to be set and repeat batch setting procedure until all batch sizes are set.
    NOTE: When brewing coffee, batch volumes will decrease due to absorption by the coffee grounds.
  3. Setting programming disable feature: If it becomes necessary to prevent anyone from changing brew times once
    programmed, you can set the SET/LOCK switch to the "LOCK" position. This will prevent any programming to be done.
    NOTE: If the clicks cannot be heard, lightly grip the incoming water line to feel when the valve cycles on and off.
Jun 22, 2014 | Bunn CWTF15-TC
This is the Krups Grind and Blue Coffee Maker purchased from Amazon 7/8/11. It is the second one I purchased. Krups factory service AND local service station phone lines are constantly busy. On this...
Sorry for the delay. I will need to look up some reference materials and drawings on this before I can aupply an acurate answer. Been one of those nights and I apoligize for the delay.
Sep 30, 2011 | Krups KM7000
I have a Krups xp2070 that sends hot water to the overflow instead of through the espresso (when trying to brew espresso).
The unit has two pressure valves that control release to the drip tray. Once they fail the hot water will go directly to the drip tray when the pressure goes up. The fix will be to replace the pressure valves (pair in series) which only cost about $20. I replaced mine and it fixed the problem. Good luck and happy espressos.
Dec 29, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Machine locke in cleaning phase, how to release?
When the machine is in the cleaning phase you must let it stop on its own. Don't add water. If it is descaling it must complete 2 cycles. The descaling cycle and the rinsing cycle. If its doing a brew cleaning it has to finish the the 1 cycle. It will tell you what to do in the menu. Walk away and let it finish.
Dec 18, 2009 | Miele CVA4070 Coffee Maker
After getting Replace Water Filter VEntilate display I replaced with Saeco Intenza water filter cartridge I have always used. However, unit does not move off this display after I press OK button. I have...
After replacing the filter in the tank, keep the button pressed; when the indicator light is flashing, then release the button.
Also at times, the gears in the brew drive assembly will not complete the cycle to the proper start position for different reasons. Some of the reasons are:
  1. Brew group jammed or blocked.
    Note: A jammed or blocked brew group can happen when the brew group starts the cycle but doesn’t finish it.
  2. Either one of the micro-switches in the brew drive has gone bad.
  3. Brew drive motor failure.
  4. Broken teeth on either of the brew drive gears.
  5. Dirty brew group, covered by coffee grinds.
  6. Brew group or gears not lubricated.
  7. Connections to the board from brew drive assy., or motor have gone bad
Oct 08, 2009 | Saeco Incanto Classic Espresso Machine
Want to remove cover of Krups Espressario XP7240
Yes it is tricky but easy once you know it. remove the bean container by pulling off the grind selector knob and removing the only screw.
Then remove the scute for the cleaning tablets. Then remove the two screws that were covered by the scute lid. Remove the water tank. Under the tank remove the two screws.
Then the trick where everyone seems to look for: The facade of aluminum can be moved off. Set the machine on the floor and pull hard upwards at the facade. This comes off (pull hard!) and four screw are uncovered. Remove them and pull then back housing of the machine (remove first the containers/drawers). Now the inner parts are freely accessible. You filter is the white valve connected to the three way valve (white plastic). You remove it by twisting it 15 degrees. Clean the inner parts (valve and spring) from coffee debris.
Feb 01, 2009 | Krups Small Appliances Espresso Machine
Froth control problems
Your vinegar did the job: it as removed the deposits, now these deposits are clogging the four holes porcelain valve.....if the froth lever is not broken.
Remove all the screw you can see on the top and under the top of it, remove the cover, unscrew the frothing device down to the porcelain valve consisting of two 4 holes discs, clean them, and voila!
Dec 22, 2007 | Krups XP 1500 Espresso Machine & Coffee...
Krups xp 4020 leaking
My Krups leaks like a sieve and I found parts (seals) available at  smallappliance.com
Sep 10, 2007 | Saeco Vienna SuperAutomatica Coffee...
Coffee Makers & Espresso Machines Logo
137 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Charles Tidwell
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
