Question about Powerware Computers & Internet
Configuration error 34, battery switch disconnected, the UPS is bypass, powerware 9390 160KVA, I need help to solve this problem.
5 Related Answers
Richard Roberts
  • 198 Answers
SOURCE: Powerware 9120. 1500i UPS
You can download the manual and other literature at
http://www.powerware.com/EMEA/UPS/9120_info.asp
The contacts for support in India are found at
http://www.powerware.com/India/Service_Support/IN_Office_Contact.asp
They offer a battery monitoring software package, at
http://www.powerware.com/India/Service_Support/IN_Battery_Services.asp
You can email support at http://www.powerware.com/pp/Check.asp?key=code1
Good luck
Posted on Feb 23, 2008
pravinbhavsa
pravin bhavsar
  • 348 Answers
SOURCE: emerge UPS 500va special power supply not working..
there is a fuse behind the ups which can be removed by opening the socket replace it if faulty
and you can operate the ups
Posted on Nov 27, 2008
Alan Hood
  • 195 Answers
SOURCE: I have a Powerware 9120 2000 UPS battery failure message
After you replaced the batteries did you perform a manual battery test?
If not do so.
Regards
Alan Hood
ami-man
UK
Posted on Mar 03, 2009
sodeep
Sudeep Chatterjee
  • 3267 Answers
SOURCE: My PC is connected to UPS.Whenever I switch on my UPSthe PC start
On the mother board at the front are 2 rows of pins to which wires are attached, going to switch(power) and the manual reset and the LED's. Usually the first 2 sets of wires--pairs of Green&White and red/black&white are for power and reset. Once u pull out the jumper-like attachments u will be able to see whats written on them. Isolate the power & reset wires. Remove them fron the pins on the motherboard. Switch on ur UPS and by simply shorting 2 pins, starts the PC. Now that u have identified the power pins, put them back after cleaning the dust,etc. If the PC behaves as before but works perfectly when the power switch connections are opened & PC works normally after just touching the 2 oins, then the switch need to be replaced......sodeep
Posted on Apr 01, 2009
Anonymous
  • 64 Answers
SOURCE: Overtemp Condition on LCD
You're absolutely right, overtemp on batteries can greatly escalate the failure of batteries, particularly older or heavily loaded ones. The fans are a fairly easy replace, if we can assist in any way, please do not hesistate to contact us.
http://www.gowithon.com
Posted on Jun 30, 2009
Powerware 9390 UPS error configuration and circuit breaker battery check
9390 Requires a UVR type battery breaker. Unfortunately a configuration error will require a service visit from a technician. The proprietary service software will have to be used to reset this.
Apr 14, 2015 | Powerware 9390 UPS System
Notice: UPS ON BAYPASS, ERROR CONFIGURATION
Need to configure upon initial startup
May 21, 2013 | Powerware 9390 UPS System
I have a powerware 9120 (6kva) and about 1 week i replaced all 20 batteries after the UPS failed. but its displaying battery disconnected when i try to power it. i cant seem to figure the problem. i tried...
Did your UPS display "Battery disconnected" or did it display "Battery Failure"? If it was "Battery Failure", for some reason the Powerware 9120 will take almost 18 hours after plugging in to power after battery replacement to correct the Battery Failure indication. Charger has to charge up the batteries, followed by an automatic battery test by the UPS. If the indication was "Battery Disconnected", you will need to check the internal fuses to see if they are blown. If the UPS keeps blowing fuses, it will require a board repair.
Jun 12, 2011 | Powerware 9120 UPS System
I, Bypass battery and nomral mode are blinking UPS bypass unavailable. I need help please
Here is the link to all of the documentation:
http://powerquality.eaton.com/Products-services/legacy/9125-info.asp
You can also contact Eaton. Eaton bought Powerware 5-6 years ago.
Toll Free: 1 800 356 5737
E-mail (Hardware): [email protected]
Mar 01, 2011 | Powerware 9125 UPS System
Attaching a generator to Powerware 9120 UPS
Power ware has a powerpass bypass switch for $200.00.
There is two inputs on this bypass switch. One for power, and one for the generator.
One ouput for your UPS. There you have it... There is your soluiton. I might add one other thing called a Power Guard, PMM117, to monitor the power of the backup generator. The time delay of this device will prevent over current from cooking your UPS power supply.
They also have a Hardwired version that is more expensive for you 5, 6 ,10KVA UPS. So a automatic bypass switch is what you need.
Jul 15, 2009 | Powerware Invensys 9120 Model 1000i...
LOOKING FOR RUSSIAN MANUAL
http://powerquality.eaton.com/Products-services/Backup-Power-UPS/EX.aspx?cx=34 u will get the required
Jun 18, 2009 | Powerware 9120 UPS System
The UPS dont go to on batteri
Replace the batteries with new one then power the UPS without load for three hours or more so that the batteries can be charged. Then disconnect or switch off power to the UPS and observe if it will till be on using the batteries. If it will be ON then your problem is solved but if it goes off then your UPS is on BYPASS
Apr 09, 2009 | Powerware 9120 UPS System
Computers & Internet Logo
173 people viewed this question
Top Powerware Computers & Internet Experts
Gruber Power...
Gruber Power...
Marvin
Marvin
Tom Chichester
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
