Question about Home Fencing
Sensor in road does not open the gate. remote switches do work. how can i check if i need a new sensor cable?
Posted by peter parkinson on
Judd Johnson
    Habit-Forming:
    New Friend:
  • 21 Answers
Check for obvious bad contacts. The next thing to check is the loop detector itself. Since you are checking inductance measured in Henry's it would be good to get the specs from manufacturer Try calling customer service.
Posted on Mar 18, 2018
5 Related Answers
Anonymous
  • 16 Answers
SOURCE: wiring diagram
ok, try purchasing a Chilton Manual (NOT a Haynes- it's junk). In it you'll find the complete wiring diagram.
Posted on Aug 15, 2008
Anonymous
  • 83 Answers
SOURCE: rear lift gate will not open
try un plugging bcm and replugging back in had one before did that worked located in centre concole lots of work to unplug. if you want can also look at rear latch harness located under drivers side above spare tire may have loose connection.
Posted on Jan 03, 2009
carl
  • 3640 Answers
SOURCE: Gate sensor keeps alerting. Have checked that
spray the switch with wd40 or similar, it may be sticking. if not replace door switch.
Posted on Apr 30, 2010
rickyrt441
Richard Hale
  • 4399 Answers
SOURCE: My 2009 Toyota Highlander lift
Thanks for choosing FixYa and welcome to the site. You need to make sure that your fuse is not blown. Check your fuse box diagram for the location. If the fuse is fine, you may have a bad switch. There could be a loose wire or a bad connection to the switch.
Posted on Apr 20, 2011
Anonymous
SOURCE: 2011 expedition rear gate will not open
Is it not under warrantee ?
The Dealer should help you with
that
Posted on Jun 05, 2012
Why does the gate open on its own during the day with nobody home?
There are several ways a gate will open. You need to check each of them but the most common issue we find when repairing gates is the exiting vehicle detection device is opening the gate.
There are two main types. The best type will be a loop embedded in the driveway. These normally open the gate by driving over them. A sensor in the operator sends an electrical wave through the loop. A vehicle affects this wave and the sensor detects it, flips a switch and opens the gate.
If the installer used standard PVC wire, and the driveway cracks to let water sit on the wires, they could change the wave occasionally and open the gate. Water can take days to soak through and remain around for days. So while you do not have rain or sprinklers going the day the gate opens, it could still be the cause.
The sensor inside the operator could also be going out. Usually, they have lights showing when they are active. If you have one, and the detection light is on, turn off the machine, disconnect and reconnect the sensor and see if the detection light comes back on.
Next check the loop wires. Physically, look at the wires wherever you can. Check the driveway for exposed wires. If you find them, call a pro to replace them. Once this is done, you need an ohmmeter. Plunge a screwdriver deep in the ground. Set the dial on the ohmmeter to measure how much resistance there is between one wire in the loop and the screwdriver in the ground. Make sure you are not touching the leads or wires with both hands since you will be measuring your bodies resistance and not the short between the ground and the wires you are looking for.
If you find anything but an open circuit, there is a problem with the loop wires and you will need to replace them. If you have a completely open circuit, then change the detector. Ideally, you have another detector for the safety loops and can switch them to see if the problem moves to the safety loops. If it does, replace the detector.
The second type of exit device is called an exit wand or exit probe.
These are overly sensitive and don't last as long as the loop detector. Your dogs collar can set it off as can a bicycle or even a workers steel-toed boots. Add to this, the propensity to fail, and if you have one of these, you have likely found the problem.
The fix for these is to pull the probe up, look for nicks or cuts in the wire and fix them, dig a deeper trench, cover the wire with PVC pipe to prevent more cuts and finally bury the wand itself at least six inches deep. By the way, if the probe cable runs next to other electrical lines, they can make the probe react too. I have heard this can be prevented by using copper pipe instead of PVC pipe.
Other causes could be a remote in someones purse or pocket going off as it bumps around, a switch used to open the gate shorting out, a call box getting signals and in general anything used to open the gate breaking down or being set off inadvertently.
Rarely, and I mean very rarely, a control board, the big circuit board controlling the gate motor itself, will go out and cause this sort of problem. Out of everything, this is the least likely.
Good luck.
May 30, 2015 | Home Fencing
I got my centurion gate motor D3. the problem is when i press the remote an LED lights but the gate does not open, i opened the motor cover and there is no light nor sound from the motor. the gate can be...
Try to reprogram your remotes.... or replace the batteries even if the l.e.d. still works (it only takes half a volt to make the l.e.d. work but almost the full charge of the batteries are needed to send a working signal.
Oct 18, 2013 | Televison & Video
The gear is getting stuck... i press on brakes and when car is in park it is hard to put on reverse.. the car runs great...
In all probability the brake sensor on the pedal is starting to work erratically. This sensor sends a signal to the shifter gate, and the gate will not open unless the brake pedal is depressed. I had it happen to me, and the only solution until i replaced the sensor was to hit the brake over and over until the stop light worked (You can check it while looking at the 3rd stop light in the rear view mirror). If the stop lights work, the shifter gate should allow the shifter to move out of park. This sensor/ switch is located about 3 inches above the brake pedal, and it is easily recognizable by the cable attached to it.
Aug 31, 2010 | 2002 Honda Accord
Replacing the brake light swith
n all probability the brake sensor on the pedal is starting to work erratically. This sensor sends a signal to the shifter gate, and the gate will not open unless the brake pedal is depressed. I had it happen to me, and the only solution until i replaced the sensor was to hit the brake over and over until the stop light worked. If the stop lights work, the shifter gate should allow the shifter to move out of park. This sensor/ switch is located about 3 inches above the brake pedal, and it is easily recognizable by the cable attached to it.
Aug 11, 2010 | 1998 Honda Accord
Stop light brake switch
Honda transmission stuck in park
In all probability the brake sensor on the pedal is starting to work erratically. This sensor sends a signal to the shifter gate, and the gate will not open unless the brake pedal is depressed. I had it happen to me, and the only solution until i replaced the sensor was to hit the brake over and over until the stop light worked. If the stop lights work, the shifter gate should allow the shifter to move out of park. This sensor/ switch is located about 3 inches above the brake pedal, and it is easily recognizable by the cable attached to it.
Jul 07, 2010 | 1998 Honda Accord
Apr 30, 2010 | 2002 Jeep Liberty
How to use 2 button remote for two mighty mule gate openers
I understanding that the chamberlin is a two button remote so as long as you have the same kind of recierver (a box hooked up in your operator that has dip switches,it recieves signals when the remote and it are set the same.) you should be able to use the two button remote on both machines. If not their is a reciever that is called multi-code and it is universal to work with all gate openers. the chamberlin remote you have will work with it.
Feb 23, 2010 | Chamberlain Clicker Universal Remote...
My accord won't go in reverse what are my options
Feb 17, 2010 | 1998 Honda Accord
Sliding gate will not close
The photo eye sensor is defective of is out of its correct posistion!
Hope this was of help!
Dec 11, 2008 | Elite Sl 3000 Ul Sliding Gate Operator
Home Fencing Logo
381 people viewed this question
Top Home Fencing Experts
Tom Chichester
 Russ Hill
Russ Hill
ray gallant
Are you a Home Fencing Expert? Answer questions, earn points and help others
