Question about Samsonite Photography
How to set a combination on a Samsonite 3 dial combo lock
Posted by lucia ward on
5 Related Answers
Anonymous
  • 195 Answers
SOURCE: get the numbers master dial combination lock
Buy the identical lock if possiable and return as defective and they will reset. Otherwise odds or 1 in 999,000 differant combos. This is airport baggage security lock.
Please rate. Thanks
Posted on Mar 28, 2009
Glen
  • 3 Answers
SOURCE: my combination for samsonite suitcase no longer works what to do?
Is it locked shut?
Posted on Jun 22, 2009
Anonymous
  • 38 Answers
SOURCE: How to reset EasyGo Travel Sentry 3-Dial Combo
well.maybe you should get a new lock because there is nothing to do with it
Posted on Sep 15, 2009
Anonymous
SOURCE: how do I unlock a samsonite combination lock
i forgot my bag password
Posted on Sep 21, 2009
Anonymous
SOURCE: forgot my 3 digit number lock on my samsonite bag
lost 3 digit no on samsonite TSA002 lock
Posted on Dec 10, 2009
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
Aug 28, 2016 | Luggage & Travel
Set combination lock
Step 1:
Step 2:
Step 3:
Try that :)
Jan 23, 2015 | Samsonite Leather Expandable Briefcase -...
Samsonite luggage
That keyhole is so that TSA can open that lock and take it off. They only time they would do that is if your are flying on a plane and the bag is in checked luggage and it needs to be searched.
May 01, 2014 | Samsonite Large Dial Travel Sentry Combo...
Travel lock
From the Samsonite site themselves:
How do I set the code on my lock? Because there are many styles of locks used on our luggage and travel bags, we ask that you please contact us with the product # of your bag and we will be happy to assist you. You can e-mail [email protected] or call 1-800-265-4933 x 220 (English) or x 237 (French) Mon-Fri 8:30 a.m. - 4:30 p.m. EST.
Dec 29, 2012 | Samsonite Large Dial Travel Sentry Combo...
How do I reset a 4 dial Samsonite combination lock
Hello sstacy1,
You can follow the steps below to fix your problem on how to reset your 4 dial Samsonite combination lock:
  1. Set the dials to 0-0-0. Find the lever or button next to the dials.
  2. 2If your lock has a lever, lower it and turn the dials to the desired numbers. Return the lever to its starting position.
  3. 3For locks with a button, push the button towards the dials and turn them to the desired numbers. Release the button.
  4. 4The lock is now set to the new combination.
Read more: How to Reset Samsonite Luggage Combination Locks ' eHow.comhttp://www.ehow.com/how_4761466_reset-samsonite-luggage-combination-locks.html#ixzz157Q4Ap
Hopefully it helps.
Thank you for using fixya
Sep 08, 2011 | Health & Beauty
HOW TO CHANGE LOCK COMBINATION IN A SAMSONITE LUGGAGE OYSTER GL
I forgot my locker combination and my luggage is locked.How can I open it??
Nov 13, 2010 | Samsonite Silhouette 11 Hardside Spinner
I have Samsonite suitcase with the lock type B. When I used it last time, it was working. Now the code system doesn't work at all. I carefully followed the instruction to lock it but the code doesn't work,...
did you do this...
STEP 1 Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2 Locate the reset button, usually placed to the side of the combination dials.
STEP 3 Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4 Release the reset button after you set the numbers to the new combination.
STEP 5 Test the combination by turning the dials to the new code to open the lock.
if you did this then I'd contact Samsonite Customer Service at 800-765-2247.
Happy New Year
Jan 01, 2018 | Health & Beauty
How to unlock 3 digit lock in samsonite suitecase
mcdevito75 here, You"ll have to find a store that carrys suitcases in your area for help or, you can try to contact Samsonite online at Samsonite.com
Jun 23, 2010 | Samsonite Silhouette 11 HWatch
How to set Samsonite combination lock
Step 1:
Step 2:
Step 3:
Try that :)
Sep 26, 2009 | Kwikset Locks & Locksmithing
Photography Logo
3,285 people viewed this question
Top Samsonite Photography Experts
Richard Schabler
Harrie
Are you a Samsonite Photography Expert? Answer questions, earn points and help others
