Cameras Logo
Question about Sony Cameras
Bower 2X Converter unable to release off of Sony a33 off of camera. Pushing the release button engages and turns but will not release from camera body.
Posted by Ellis Smith on
2 Related Answers
Anonymous
SOURCE: Unable to turn on my labtop (gateway 7326GZ) computer.
I saw this part available really cheap from Computer Parts Outlet.com
Posted on Jan 27, 2009
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: Filter stuck in a Frigidaire FRS26R4A Side by Side
Removing and replacing a water filter - upper right hand corner inside location
Filters situated up front in the refrigerator compartment of Frigidaire-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Open the door of the refrigerator compartment of your Frigidaire brand side-by-side refrigerator. The filter is located in the upper right hand corner. It has a push button for quick release just to the right of the filter.
  2. Locate the icemaker On/Off power switch and place it in the OFF (o) position.
  3. Push in on the filter release button and pull the filter all the way out to remove it. Remove new filter from its packaging and remove the protective plastic caps. Insert the new filter in the same manner it was removed. Make sure to push in firmly on the filter until you hear the filter cartridge click in place.
  4. Return the icemaker's power switch to the On (l) position.
  5. Condition the filter by running water through the dispenser for about three minutes. This will flush the filter of all fine carbon particles.
  6. In some models, you will have to reset the filter status light. It is located on the ice and water dispenser control panel. Push in on it for ten to fifteen seconds until the green, red, and amber lights flash. If your refrigerator model does not have a filter status light, you should make a note on a calendar, or place a month sticker on your filter to remind you to replace the filter again in six month's time.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator or shut off the water supply when replacing it. Also, this filter should be replaced every six months.
Posted on Dec 06, 2010
Where can I purchase a Bower Quick Release plate for 40" WT3110A Compact Tripod Stand ?
Not to sound like a smart alec, but I found one at a camera store a number of years ago. You might also try E-bay, Amazon or Craigslist.
I HAVE A SOLIGOR 2X CONVERTER AND I NEED A NIKON ADAPTER IS SUCH A THING AVALIBLE
There are a lot of adopter rings available. But most will turn the combination into a MF lens. Most non Nikon tele convertors, only can be used in MF when put on a Nikon camera, so I don't think you lose a lot when you find a Soligor Nikon adopter ring.
I WANT DOWNLOAD A JVC DIGITAL CAMERA GV-A33 DRIVERS
I expect you mean model GC-A33, as there is no model GV-A33.
There is a download at THIS LINK
4helpful
DSC-W150 SteadyShot says turn power on & off & lens pops in/out
I had the same problem with my Sony DSC-W150 camera. It turned out to have an easy fix. At the same time, press the power button and depress the shutter button halfway (the one you snap to take pics) as if you were trying to engage the autofocus without pressing the button down entirely. The lens will attempt to autofucus, which in my case was enough extra power to dislodge whatever debris/sand had clogged the lens. Hope this works for you!
Dropped the camera and now...
Sounds like the chassis under the shutter button has somehow distanced itself from the shutter release button, maybe bent away from the button? Its s stretch but that maybe the problem. The button is designed to have 2 contacts in it, the autofocus switch and the shutter release depending on how much you press it, like most cameras
Top Sony Cameras Experts
W.L.
matt
matt
Darran Hatten
Are you a Sony Camera Expert? Answer questions, earn points and help others
