Question about Firearms
Which is the best spotting scope under $ 250?
Posted by Adam Howard on
Mills Jack
    Habit-Forming:
  • 49 Answers
Bushnell Trophy Xtreme Spotting Scope
Bushnell Spotting Scope has extra power for extra range; its BaK-4 Porro-prism design delivers magnificent clarity in a traditional design. The multicoated optics ensure maximum light transmission for the brightest and take the images more colorful and clear. If you are searching Bushnell Scope that can be used for different activities, you should consider Bushnell Trophy Xtreme Spotting Scope Review.
The highly refractive BAK4 Porro prisms diminish spherical deviations for increased edge-to-edge sharpness and help progress depth of view. This combination of optics and coatings creates a spotting scope that produces clear, bright, highly contrasted images with the exact color transmission.
The rubber-armor structure stands up to demanding use. This scope is 100% waterproof and fog proof for wet hunting conditions. It also Comprises compact tripod with window mount, compact soft case, and waterproof hard case.
Posted on Mar 17, 2018
2 Related Answers
mills4177
Mills Jack
  • 49 Answers
SOURCE: What would be the best spotting scope Under $200?
Celestron Ultima 80 Spotting Scope
This economical device is genuinely popular on the market. It is a large aperture spotting scope affordable for everyone. It needs more cost for a conventional 60mm scope. It is helpful in poor lighting conditions. They are great for long-distance viewing. You can use it in twilight or under heavily overcast skies.
The zooming lens of this scope is capable of zooming from a mere 20X up to a massive 60X magnification. You can easily handle it. The zooming knob is very smooth. It has large 80mm objective lens. It gives you over 77% more light grasp than a conventional 60mm scope. It has built-in 80mm objective lens are outstanding for light gathering.
It is a refactor-type scope. The achromatic objective lens used in this scope. The product comes built with quality materials. It has outstanding light transmission capabilities. Enhancement of brightness becomes easy. It also increases the clarity of the spotting. This scope is a well-built device. It can be used efficiently in rugged conditions. The device's rugged nature makes it a perfect thing in all circumstances. It is waterproof too.
Posted on Mar 07, 2018
mills4177
Mills Jack
  • 49 Answers
SOURCE: Which is the best hunting spotting scopes?
Vortex Razor HD Spotting Scope
This is a spectacular spotting scope which is a masterpiece of the well-known, vortex optics.
The Vortex Razor HD Spotting scope is filled with the premium high density and extra-low dispersion glass which will definitely give you the ultimate resolution for every image by providing rich color and contract.
Moreover, the ultra-hard-coated Armor Tek will efficiently protect the exterior of the lenses from any particular scratches, prevents staining from oil and dirt too.
As for the linear field of view, you can get 117 -60 feet per 1000 yards. The angular field of view for this spotting scope is 2.2-1.1 degrees. As for the close focus, it can come to an amazing 16.4 feet. This spotting scope would be perfect for getting really close and personal during your hunting surveillance.
The eye relief for the Vortex Razor HD spotting scope ranges from 18 mm to 20 mm. For this eye relief, it will be very comfortable to scope even with glasses on. The exit pupil can be adjusted from 1.42mm to 4.25mm. Being able to focus with this spotting scope is extremely easy too. Amazing detail too if you want to sight further, even into outer space!
To touch on the physical aspect of this spotting scope, it is generally large in size. The spotting scope has an 85 mm objective lens and an eyepiece which has a magnification that can be adjusted from 20x to 60x. The objective lens will provide you with image of great clarity which is made by Vortex.
Not only that, this spotting scope has Dual Focus Knob which is necessary for ultra-precise focusing while making it much easier for you to manipulate the focus of this scope. There is a course knob and a fine knob to provide for maximum manipulation during focus. The length of this spotting scope is 15.3 inches while of this scope is 65.7 ounces. Although it does feel a little heavy, this scope is extremely sturdy!
To extend more about the objective lens, it can significantly reduce the amount of glare while being immune to raindrops and even snow since the Vortex Razor HD spotting scope is waterproof, rugged and even fog proof.
Also, there is a helpful finder on the side of the spotting scope. The balance is extremely good too even on or off the tripod.
Furthermore, the Vortex Razor HD Spotting Scope has a Dielectric prism coating which will provide the clearest and brightest images you will ever see with a spotting scope. It is also known for the great color accuracy for every single images. All and all, beautiful to look through and extremely pleasant to look at.
The Vortex Razor HD Spotting scope also comes with a proprietary XR anti-reflective coating which will significantly augment the light transmission for maximum brightness while you are spotting with this premium scope. Basically, the XR lens coatings will increase light transmission by providing multiple coatings on every single air-to-glass surfaces which are present in the spotting scope.
As for the design, the Vortex Razor HD spotting scope has an angled body design which is greatly sought for because it will allow a lower mounting height making it much more stable in the wind while giving more comfort when you are looking through the spotting scope with glasses for a long period of time.
In addition, the spotting scope comes with a triplet apochromatic lens which greatly reduces chromatic aberration. Also, the Vortex Razor HD has a built-in sunshade which can be equipped on a sunny day. The XT optical design also helps in the reduction of aberration while aiding in making distortion-free images which is needed for accurate image.
The Vortex Razor HD spotting scope uses Porro Prism which is popularly known to offer maximum image quality and excellent performance.
You can use this spotting scope in most harsh environment too. It is built with an O-ring sealed to the optics which is to prevent moisture, dust and even debris to stick onto the optic. The O-ring seal will also result in waterproof performance
Not like any other spotting scope, this scope is filled with argon gas to inhibit internal fogging effectively as you bring it out to different terrain.
To discuss a bit about the accessories, the Vortex Razor HD spotting scope can be equipped even with smaller tripods. You should also be careful with the strap because you can easily lose your grip on the scope allowing it to slip off.
If you are planning to participate in any serious event such as an Olympic tournament in archery, this would be the perfect spotting scope for you!
To conclude, this is one of the best spotting scope that will deliver a level of optical quality and even resolution unmatched by many of its peers. Not the mention the great color fidelity. As for this HD spotting scope, you can definitely hope for distortion-free images, augmented light transmission, increased resolutions with outstanding accuracy and color contrast which makes this spotting scope almost irresistible.
As a bonus, the Vortex Optics also provide VIP Unconditional Lifetime Warranty! No need to worry about spoiling the scope. This "Very Important Promise" to you will make sure that you are taken care of with unlimited lifetime warranty which is fully transferable. You will not have any warranty card to fill out while no receipts are required to change the product, all you have to do is just to contact Vortex Optics. Even so, it is important to note that the VIP warranty will not cover the loss of product, theft, deliberate damage or even cosmetic damage. All of these damages will not reduce the performance of this product.
Posted on Mar 10, 2018
What are the most expensive rifle scopes?
Nightforce, Leupold and Schmidt-Bender Scope will get up there in the price point. Schmidt-Bender glass especially will be quite expensive. Their high end glass can easily exceed $10,000.
Jun 04, 2018 | Firearms
HOW TO MOUNT SCOPE
Hello, Malcolm -
There are quite a few web pages with instructions on how to mount a scope on a rifle.
This web page may prove instructive:
https://www.shootingillustrated.com/articles/2017/3/22/the-right-way-to-mount-a-scope/
This is a link to a YouTube video demonstrating the mounting of a scope:
https://www.youtube.com/watch?v=8rFOtmWqBUI
You can find more web pages and videos with instructions on how to mount a scope by using your favorite search engine (Google, Bing, Duck Duck Go, Yahoo, etc.) and entering the following search phrase, with quotation marks as shown:
"mounting a scope"
Best wishes.
Mar 09, 2018 | Firearms
Best concealed carry firearm?
That's a personal decision that only YOU can make.
Jan 04, 2017 | Firearms
Firearms Logo
145 people viewed this question
Top Firearms Experts
Marvin
Marvin
jws1013
john h
Are you a Firearm Expert? Answer questions, earn points and help others
