Question about Mercury Outboards - Zinc Merc Outdrive
I have a mercury 4.5 hp it’s getting to much fuel why it won’t rain ebb up until I take fuel line off
Posted by Tim Chlouber r on
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
1976 115 hp mercury outboard motor manual
fuel goes in at connector then to fuel pump then to carbs ! remove connector off fuel line and prime fuel up so you know you got fuel ! then reconnect to engine and prime up again till you see filter filling and bulb should harden , then remove a drain screw from carb bowl and prime again and see if fuel comes out of all carb drains ! if yes then start engine with or in water with kill lanyard on if ok then good ! not then check sparks on all plugs putting them against the head for earth and crank to check ! if ok then i would remove carbs and clean the jets etc ! compressions 100psi or more on all cylinders ! less means recon pistons etc !
Jul 28, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
Mercury outboard 45 HP
Can you turn flywheel,check compression,check spark,check fuel line,pray
Oct 19, 2012 | Boating
1994 3.0 Merc. Sable (153K miles). Intermittent no start (cranks, but won't turn over). When it does start, it sometimes runs rough until it warms up. The problem first started in the summer time a couple...
This could be fuel not reaching the injectors. Check for a clogged fuel filter or fuel lines. Dirty or clogged fuel injectors. Also difficulty starting after rain can be caused from old plug wires. I hope this helps.
Mar 15, 2010 | 1994 Mercury Sable
98 Mercury Tracer starts missing and dies after 60 - 80 miles
U can go to any autozone, kragen or other chain auto parts stores and they will run the trouble code test for free, let me know what they find if anything, this also may be a fuel pressure problem
Mar 09, 2009 | 1998 Mercury Tracer
Mercury Outboards - Zinc Merc Outdrive Logo
95 people viewed this question
Top Mercury Boating Experts
Mike
ray gallant
john h
Are you a Mercury Boating Expert? Answer questions, earn points and help others
