Televison & Video Logo
Question about Vizio Televison & Video
My vizio d65u-d2 tv will power on then after a few minutes the screen will go black. Still have sound and can still see the picture if you shine a light at the screen. We tried replacing the led driver but still does the same thing. What else could it be?
Posted by Melissa cates on
Gary F
    Sergeant:
  • 245 Answers
Most common problem with LED TVs is the power board fails.
Posted on Mar 17, 2018
1 Related Answer
Larry
  • 4627 Answers
SOURCE: vizio 65in Model D65u-D2 I have a black screen with sound.think it may be led driver but i can change format to small and take off HD channel and it will stay on. would this still be the led driver?
Most likely not...sounds like a software issue to me
Posted on Dec 13, 2017
Hi, I have Vizio d65u d2 Screen goes black after 3 minutes, I change power board supply and led board, but still same problem
Hello
Make sure the connectors are snugly in place and that the set in not i a position that stress the boards, reset all settings then
change the picture mode to standard and auto brightness to medium
Good Luck
Mr.Mike
I have a vizio d65u-d2 i turn it on and after 5 minutes the screen goes black it still has sound though any ideas as to qhat it could be?
Let us know what exact model this is. It is possible that this is caused by a bad power board which then causes your backlight to turn off, but can also be a T-con or main board issue. Let us know if only your picture turns off or if you lose sound as well and if the picture comes back on. You do want to try to reset your TV. Unplug it and push and hold the power button for about 30sec-1min then plug it in while holding the power button depressed. If that does not help, remove the back of your set and post some good images of your boards with your question. That way we can see what you see and could try to assist you further.
Why is my D65U-D2 Vizio screen going black?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board./
Top Vizio Televison & Video Experts
Marvin
Marvin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
