Its not common rail and its not electronic injectors
There's this website www.reliable-store.com
They
have books on ALL vehicles.
it covers wiring diagrams, electrical diagrams,
fuse diagram, torque specs, PCV, error codes, fault codes, service info, repair info, parts info, owner's/service/repair/parts/maintenance manuals etc everything totally..
I have 1987 toyota 4runner model and I keep servicing and when needed repair it on my own. worth it !!!
SOURCE: diesel engine
Yep coded. someone with a ford diagnostic machine or equivlent should ne able to do it though, not a tough job if you know what your doing.
Good luck Davelee
SOURCE: after mud and water went
your filters should have prevented mud from getting to your injetors, water in the system can cause some problems but nothing so drastic as to change the injectors injector pump or the rail....change your filters, water collectors. make sure there is no more mud or water in your tank . not familiar with that particular engine but you may have to bleed the injection system....oh and get a new mechanic
How do you know there is fuel in the fuel pump? Have you had someone check it out?
