Washing Machines Logo
J
John Kovach Posted on Mar 16, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have had two instances where the timer for a zone is not shutting. On the first occasion, I replaced the solenoid last Sunday. My wife stated that the tree zone was watering on Tuesday.
It was still watering Friday afternoon and had a good amount of flooding. Turned the timer to the off position, however, water continued to run. Turned off sprinkler system water supply to get water to stop flowing. Could this be an indication that he timer is bad or just a coincidence of a second failed solenoid?
  • Steve Pack
    Steve Pack Mar 17, 2018
    Hi John Kovach, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Replace control valve with a new one. It is a balanced valve and requires the water to get to top of diaphragm to close valve.. I had to replace all my control valves after many years of service. The cost of parts outweigh the price of new valve.
Jim Goldsmith
Level 3:
  • Washing Mach... Master 2,005 Answers
  • Posted on Mar 17, 2018
Jim Goldsmith
Level 3:
Answers
2005
Questions
Helped
736805
Points
6152
Replace the timer/controller as your timer is still calling for water and not shutting off
5 Related Answers
Anonymous
  • 135 Answers
  • Posted on Feb 19, 2007
SOURCE: Aprilaire 760 Humidifier water continues to run
You need to determine whether the problem is in the solenoid or in the furnace electronics. You could put a voltmeter on the solenoid connection to see if the furnace is still holding the solenoid open after the blower stops. This will tell you whether it is the solenoid or not.
Anonymous
  • 76 Answers
  • Posted on Jul 08, 2007
SOURCE: Maytag washer PAV2300 water over flow
tidalwave If the water continues to flow even when the washer timer and the power to the washer are off then you are right and the water inlet valve has to be replaced. If it does it only when the washer is on then it could be different problems. In that case the first thing you have to check is the water level switch. This is the device which controls the water level. Remove the power first.Open the control panel and you will see the switch on the left side. There is the clear plastic hose connected to the switch. Make sure the hose is not loose. This is one of the most common cause of overflow. If it got loose, drain out all water from the washer before you reconnect the hose. If this is not the issue then you have to check the continuity across the water level switch therminals. When there is no water you should measure the continuity across therminals 11 and 12 (gray and orange wires). Whet the tub has filled up with water you should measure the continuity across therminals 11 and 14 (gray and light blue wires). If the continuity is wrong replace the water level switch. If you are going to do it, make sure there is no water in the tub before you will remove the clear plastic hose from the old switch. Good luck. Gendos. post back...
Amigaman
Gerald Griffin
  • 248 Answers
  • Posted on Oct 08, 2007
SOURCE: water overflow
Are you on a well? Often people with a lot of sediment in water get sick of the screens in water valve plugging up so they remove them. NEVER remove these screens. If any sediment gets into valve it can hold it open causing flooding. If you unplug unit and water still comes in you must replace valve.
douglas smith
  • 1462 Answers
  • Posted on Aug 10, 2008
SOURCE: hygena dishwasher
there is a pressure stat but these are reliable. a common fault is the wiring loom broken where it goes round the corner at the bottom of the door. take outer door panel off and inspect the wiring loom for breakage
Anonymous
  • Posted on Dec 06, 2008
I had the same problem and went out to a website for Maytag washers. That website advised that the problem could be mechanical or electrical. In my case, the problem was a clogged tube and it took only ten or fifteen minutes to fix.
0. Unplug the machine.
1. Open up the front of the washer. Along the left hand side is a long transparent tube. The tube connects to a wallet size container on the side and near the bottom of the tub.
2. Inspect the transparent tube. It may be clogged where the tube meets the wallet sided container.
Note: When the tub is full, it creates pressure in that wallet size compartment which sends air up that tube to a pressure switch located within the panel at the top of the washer. The pressure switch flips and tells the machine - stop filling the tub with water. My machine had a visible clog in the bottom of the tube that carries the air from the bottom of the tub up to the pressure switch.
3. Disconnect the tube and clean. I used a pipecleaner to get most of the mold out. To completely clear the tube, remove the top panel and disconnect the tube from the pressure switch in the top panel and blow air down the tube.
4. Reconnect, test - and you should be good to go. If not, your pressure switch may be dead.
1helpful
One Lawn sprinkler zone is shutting off prematurely
it unscrews, be sure that water is off at shut off valve.
tip
Daylight Saving Time Changes for SmartSet Clock/Radios
Dear Emerson SmartSet® Clock/Clock Radio Owner:
Your Emerson SmartSet® Clock or Clock Radio includes Emerson’s patentedAuto Time Setting System that
automatically sets the clock to the correct year, month, date, day and time, the first time that you plug it in, and
after every power interruption. It also includes a built-in long life lithium battery that can maintain the time and
alarm settings for up to 5 years, or even longer.
As an added benefit we have programmed the internal SmartSet® computer to automatically adjust for Standard/
Daylight Saving Time changes through the year 2097. TheDaylight Saving Time information programmed into
all SmartSet® models was based on the United States Uniform TimeAct of 1966, which formalized theDaylight
Saving Time period that we observe today. CurrentlyDaylight Saving Time begins on the first Sunday in April
and ends on the last Sunday in October.
The new Energy Bill that was signed into law by President Bush in August 2005 includes a provision to
extend Daylight Saving Time. Beginning in 2007 Daylight Saving Time will begin on the second Sunday in
March and end on the first Sunday in November.
Of course this is a situation that is beyond the control of Emerson, or any other company that produces
devices with an automaticDaylight Saving Time adjustment feature. For example most computers, PDA’s, and
many other devices also have automatic DST adjustments. Manufacturers of these devices must now begin to
make adjustments to the automatic DST software to agree with the new DST timing for 2007.
Beginning in 2007 the current automatic DST default settings in this device would no longer be correct. It
would then be necessary for you to manually adjust the TIME ZONE setting 4 times each year as follows:
1.) On the second Sunday in March you would have to set your clock to the next lower number time zone.
For example if you lived in the Eastern Time zone (Zone 02) you would then change your clock to Zone
1 to move it ahead by one hour.
2.) On the first Sunday in April, this clock will automatically advance by one hour. You must then set the
clock back to your correct time zone. For example if you lived in the Eastern Time zone you would set
your clock back to Zone 02.
3.) On the last Sunday in October you would again set your clock to the next lower numbered time zone.
4.) On the first Sunday in November you would again set your clock back to your correct time zone.
Instructions for changing the Time Zone setting are found in the Owner’s Manual.
We apologize for any inconvenience this may cause due to circumstances that are beyond our control.
Printed in China
508-02
1helpful
2answers
All six zones run but cannot get one of the zones to completely shut off so I get a substantial leak so I turned of the system what should I look for
Hi Michael:
The solenoid for the leaking zone will probably have some debris in it. You could try to dismantle and clean it, otherwise, replace and you should be OK.
Cheerfuls.
How to wire
First check the solenoids by performing a continuity test on all of them. For all the solenoids that test good, power each one with 24 volts to make sure that the plunger moves. Then go to the timer and initiate an ON cycle for, say, zone one. Go to the zone 1 connector on timer and check for presence of 24 volts ac. If not present try zone 2 for output. If nada then there is something wrong with the electronics of the timer.
I have city reclaimed water source for my sprinkler system. My problem is I connected the waterlines to the solenoid (1) and then the zone index valve (4 zones ), then i wired the solenoid to my spr
What model number of timer? I have to see exactly which timer you have to answer question.
What wire goes where?
Are you using 120Volts?
What is output voltage of timer?
What voltage is solenoid? 24Volt or 120Volt?
Copy following links for Orbit manuals:
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=02&Type=Timers
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
Hunter pro C will not allow all zones to water.
The fact that you are getting no error message indicates that programming is not right, or there is electrical short between timer and sprinkler solenoid:
With all digital timers, it is important to clear memory before starting, and then double-check there are no conflicts in programming.
Page 22-23 of the manual has quick-check procedure for identifying shorts that would cause problems.
Check outlet with circuit analyzer to check for correct polarity and grounding.
Google search Hunter Pro C manual to download searchable pdf manual
Keep in mind also that digital timers are susceptible to line noise, and power surge. Simple power outage can disable digital timer. There are no replacement parts.
That's why I recommend good old fashion 14-day repeat-cycle mechanical sprinkler timer with fewer features, but replaceable parts.
For example T8845PV with 24Volt ac output
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html#T8845PV
My timer counts down but no water is coming out of the sprinkler head
If it only one head/zone that does not work, it may be that you have a bad solenoid for that head/zone. Check the solenoid for any visual hints that the solenoid has failed, such as rust, and recheck that all wire connections are still waterproof. Another possibility may be the transformer, check is the resistance if you see an infinite reading then it will need to be replaced. Here is a link that may be of assistance: http://rainbird.custhelp.com/app/answers/detail/a_id/17
Hope this has helped you, and plese don't forget to rate us. Thank You.
1helpful
How do I disable the Daylight Savings Time function? the dates for DST have changed and the alarm is still set to the old date changes.
See the comments under Petewete. There is no way to disable it on the T301B model. Changing time zones doesn't help because all 7 zones observe DST, or at least they did before 2005. (Now Hawaii Zone 7 does not). I know because I tested all zones. The workaround is complicated: before each time change, pretend it is the old DST date (1st Sunday in April or last Sunday in October) by resetting your date. My spouse says to fix the problem by hitting the snooze button with a 20-pound sledge hammer.
2helpful
Emerson smart set clocks
Sorry it took so long to give you a answer to your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day! Dear Emerson SmartSet® Clock/Clock Radio Owner: Your Emerson SmartSet® Clock or Clock Radio includes Emerson?s patentedAuto Time Setting System that automatically sets the clock to the correct year, month, date, day and time, the first time that you plug it in, and after every power interruption. It also includes a built-in long life lithium battery that can maintain the time and alarm settings for up to 5 years, or even longer. As an added benefit we have programmed the internal SmartSet® computer to automatically adjust for Standard/ Daylight Saving Time changes through the year 2097. TheDaylight Saving Time information programmed into all SmartSet® models was based on the United States Uniform TimeAct of 1966, which formalized theDaylight Saving Time period that we observe today. CurrentlyDaylight Saving Time begins on the first Sunday in April and ends on the last Sunday in October. The new Energy Bill that was signed into law by President Bush in August 2005 includes a provision to extend Daylight Saving Time. Beginning in 2007 Daylight Saving Time will begin on the second Sunday in March and end on the first Sunday in November. Of course this is a situation that is beyond the control of Emerson, or any other company that produces devices with an automaticDaylight Saving Time adjustment feature. For example most computers, PDA?s, and many other devices also have automatic DST adjustments. Manufacturers of these devices must now begin to make adjustments to the automatic DST software to agree with the new DST timing for 2007. Beginning in 2007 the current automatic DST default settings in this device would no longer be correct. It would then be necessary for you to manually adjust the TIME ZONE setting 4 times each year as follows: 1.) On the second Sunday in March you would have to set your clock to the next lower number time zone. For example if you lived in the Eastern Time zone (Zone 02) you would then change your clock to Zone 1 to move it ahead by one hour. 2.) On the first Sunday in April, this clock will automatically advance by one hour. You must then set the clock back to your correct time zone. For example if you lived in the Eastern Time zone you would set your clock back to Zone 02. 3.) On the last Sunday in October you would again set your clock to the next lower numbered time zone. 4.) On the first Sunday in November you would again set your clock back to your correct time zone. Instructions for changing the Time Zone setting are found in the Owner?s Manual. We apologize for any inconvenience this may cause due to circumstances that are beyond our control.
Top Washing Machines Experts
john h
