Question about HP LaserJet Office Equipment & Supplies
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Posted on Jan 28, 2008
SOURCE: hp laserjet 1320 printing blank pages
check printer door, there is a small plastic piece wich pushed down (to open) lasser scaner cover. if this piece is broken you can get blank page
Posted on Sep 24, 2009
SOURCE: Hp LJ 4345 mfp vertical line down printed copies
Dirt.
Open the ADF, the top of the scanner/copier.
The ADF glass is the thin strip of glass on the left. Damp cloth with windex or any glass cleaner. Scrub the strip of glass.
Posted on Jan 29, 2010
SOURCE: LaserJet M4345 MFP Printer: how to cold reset in HP LaserJet M4345 MFP...
[email protected]
To perform a cold reset
1 Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. This might take up to 20 seconds.
3 Press 3 four times until COLD RESET appears on the control-panel display.
4 Press 6 one time. The MFP continues its initialization sequence.
Posted on May 07, 2010
SOURCE: HP 4500 Printer blank pages
Every so often? Sometimes if the printer is set to print on Legal sized paper (8.5" x 14") it will take an extra blank sheet if the sheet sizes are letter. This may cause every other page to be picked up and drawn through the printer as a non printed page.
Posted on Jan 20, 2011
Jul 07, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
Mar 15, 2014 | HP Office Equipment & Supplies
Oct 31, 2013 | Rhinotek Digital Imaging Suppl HP Laserjet...
Aug 17, 2012 | HP LaserJet Office Equipment & Supplies
Jun 08, 2012 | HP LaserJet Office Equipment & Supplies
Jan 30, 2012 | HP LaserJet M3027x MFP Printer
Jan 30, 2012 | HP Laserjet CM2320nf All-In-One Color...
Sep 09, 2011 | HP LaserJet 4345mfp Printer
Feb 12, 2009 | HP LaserJet CM1017 MFP All-In-One Color...
Dec 30, 2020 | HP LaserJet 1320 Printer
53 people viewed this question
