0722585474
South Africa immigration phone numbers:
http://www.dha.gov.za/index.php/immigration-services
United Kingdom passport holders exempt from visas/
http://www.dha.gov.za/index.php/immigration-services/exempt-countries
SOURCE: Kenwood A901
A compatible triac can be purchased from Maplin in South Africa.
The Maplin part number is UK54J and this relates to an 8 amp
600 volt triac - BTA08-600B. In the UK the price is £1.30.
SOURCE: '95 Camaro wheel alignment specs....
its your lucky day.. i want dave mathews tickets for this :) ok for my camrao which is a 97 z28, which should work for yers heres all the tire and whell specs
Front spec
caster
set ....5.0deg +- 0.5 (+- suppose to be +on top of -)
check...5.0 +- 1.0
cross caster
set....0.0 +- 0.7
check....0.0+- 0.7
Camber
set 0.4 +- 0.5
check...0.4 +- 1.0
Cross camber
set...0.0 +- 0.7
check..0.0 +- 0.7
individual toe
set 0.0 +-0.1
cehck..0.0 +- 0.1
total toe
set 0.0 +- 0.2
check 0.0 +- 0.2
Steering wheel angle
set 0.0 +- 3.5
check ...0.0+- 3.5
i have rear specs too let me know if you need them..Anything you need to know about a f-body just let me know i have 6 manuals on them :)
SOURCE: How can I activate blackberry messenger on blackberry 9930 in south africa
You first need to buy R60 airtime for the network you are using such as MTN, Vodacom, Cell C etc. That R60 will be the amount you need for (BIS) Blackberry Internet Service. You need BIS to enable BBM (Blackberry Messenger) to work. Once you have topped up your airtime with R60, you need to dial *141*11# which should bring up the option to activate BIS. Choose BIS and not any other option. BIS is usually option 1, but just make sure you select to activate BIS. Once BIS is activated then you can go onto BBM (Blackberry Messenger) and you should be able to send messages. You then have internet access as well. The great thing about the BIS is that it lasts for a month, without you needing to pay anything after the R60 to send as many messages as you like for free on BBM, plus you can use the internet on your phone as much as you like too! I am experiencing a problem getting BIS on my Blackberry Curve which I shall ask a question about on this site!! Good luck :)
