Question about Garmin nuvi GPS
2018 Garmin Nuvi 265w webupdater for Mac - nuvi Garmin GPS
  • Michael Grimes
    Michael Grimes Nov 13, 2019
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? I need an actual question.
5 Related Answers
sharcnet
SHARCNET-USA
  • 2130 Answers
SOURCE: Garmin Nuvi 265W, T, or WT
W = wide screen version, 4.3" diagonal screen GPS
T = Includes Traffic receiver
WT = widescreen & with traffic receiver
If I answered your question, please rate my solution as fixya.
Thanks
- Jim
SHARCNET-USA
Posted on May 12, 2009
Anonymous
  • 86 Answers
SOURCE: nuvi 265w Operating manual
You can find the manual here: http://www8.garmin.com/manuals/2675_OwnersManual.pdf
Posted on Jun 04, 2009
Anonymous
  • 1111 Answers
SOURCE: my Garmin Nuvi 265W will not turn on
plug it in to the computer for a few hours, then hold the power switch to the on position for up to 15 seconds.
if that fails, disconnect it from the power source, then press and hold the lower right corner of the screen, while holding the lower right corner, switch the power to the on position. once you see the message "do you really want to delete your data" select yes, then follow the on screen instructions
bill
Posted on Dec 11, 2009
HarryHarley
Harry
  • 343 Answers
SOURCE: Garmin Nuvi 265w voice command stopped working.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you are not receiving any sound on your Nüvi 2xx the first thing to check is that the sound is not muted. To ensure that your units sound is not muted please perform the following:
  1. Turn the device on
  2. Press the Volume button on the ‘Where To?’, ‘View Map’ screen
  3. Ensure the Mute box is not ‘checked’
If the mute button is not ‘ticked’, you will need to change the voice to ensure that the preset voice is not faulty:
  2. Touch the Tool icon
  3. Touch Settings
  4. Touch Language
  5. Touch the language voice next to Voice
  6. Scroll through and select another appropriate voice
If changing the voice is not helping you will need to ensure that you are running the latest software which can be done by installing a program called WebUpdater. WebUpdater can be installed via the link below:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Once updated please allow the unit to reboot which will ensure the software successfully installs.
If after following all the above the final steps would be to perform a master reset:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers on. After 5-10 seconds you will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Please follow the on screen prompts on the nuvi and when completed place your device in an area with a clear view of the sky until it acquires satellites.
Posted on Jan 19, 2010
HarryHarley
Harry
  • 343 Answers
SOURCE: Garmin Nuvi 265W just will not switch on!
Bad or very low battery
Replace at Garmin
But first know this:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sounds like a bad or low battery. Do you have the Garmin approved charger / car charger?? You may have to send your 265 in for battery replacement or try this:
There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F respectively) then it will not charge. When connected to external power it will only be operating off of external power.
2 - The Quest® and Quest® 2 will not charge using a USB cable.
Hi just up dated my garmin nuvi but now cant locat satellites pleaSE help
I can help you reset and fix your Garmin Nuvi 265W.
A new webupdater was released at the end of March, so you might want to check below that you used that version. I also recommend backup up your favorites and performing a hard reset after the update. Detailed instructions for both are below.
There are three steps to take to get your Nuvi 265W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265W Manuals here.
tip
Nuvi 265W Webupdate
Garmin Nuvi 265W Webupdate
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 265W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Download Nuvi 265W Manuals here.
Garmin Nuvi 265W Hard Reset Here.
Garmin Nuvi 265W Favorites Backup here.
tip
Garmin Nuvi 265W Favorites Backup and Restoration Procedure Models: Garmin Nuvi...
Would you like to back up a copy of your Garmin Nuvi 265W Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
Download Garmin Nuvi 265W WebUpdater here.
tip
Garmin Webupdater Download Pre-XP Windows (Legacy) Models: Garmin Nuvi 200,...
Looking to reflash the firmware / system software for your Garmin GPS device? Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
To download Webupdater for Legacy Windows (Pre-XP), the most recent software (version 2.4.0 as of December 20, 2006), click here.
I hope that helps.
To download Webupdater for Windows (March 31, 2010), click here.
To download Webupdater for MAC (April 23, 2009), click here.
tip
Garmin Webupdater Download MAC Models: Garmin Nuvi 200, 200W, 250, 250W, 260,...
To download Webupdater for MAC, the most recent software (version 2.0.6 as of April 23, 1009), click here.
I hope that helps.
To download Webupdater for legacy Windows Pre-XP (Dec 20, 2006), click here.
tip
Garmin Webupdater Download Win Models: Garmin Nuvi 200, 200W, 250, 250W, 260,...
To download Webupdater for Windows, the most recent software (version 2.4.2 as of March 31, 2010), click here.
I hope that helps.
To download Webupdater for MAC, click here.
tip
Garmin Webupdate Download PreXP
Garmin Webupdate Download Pre-XP Windows (Legacy)
I hope that helps.
tip
Garmin Webupdate Download MAC Models: Garmin Nuvi 200, 200W, 250, 250W, 260,...
I hope that helps.
tip
Garmin Webupdate Download Win Models: Garmin Nuvi 200, 200W, 250, 250W, 260,...
I hope that helps.
tip
Download Nuvi 265W Manual Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W,...
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 265 or 265W GPS?
Would you like a digital copy for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
GPS Logo
Top Garmin GPS Experts
Tom Chichester
Steve P
Steve P
Aron
Are you a Garmin GPS Expert? Answer questions, earn points and help others
