Question about Video Game Consoles & Games
Resetting parental controls. Im locked out. trying to set up WIFI.
Posted by John Clark on
5 Related Answers
Anonymous
  • 934 Answers
SOURCE: Parental Control Lock
I'm really guessing here - -but while you're in the parental controls screen I believe you can use 0-0-0-0 as a backdoor key. It's different for every manufacturer, Philips uses 0-7-1-1 example. But the users's manual for that TV says that the "default" is 0-0-0-0.. Don't really understand their use of that terminology so it's merely a guess... But here's something I am really sure of;;; The owner's manual can be downloaded for free at the Vizio web site: http://www.vizio.com/support/downloads/ and their support line is: 1-888-849-4623 or you can email tech support at: [email protected] Hope this helps. Good Luck Bill
Posted on Jun 06, 2007
Anonymous
  • 1067 Answers
SOURCE: RCA -parental control
Unplug unit. Hold power button in and plug unit in while holding power button till it beeps or flashes. This will erase eveything and you'll have to start from begining. good luck. This doesn't always work and the unit may have to be reset from the factory
Posted on Jan 27, 2008
Anonymous
  • 129 Answers
SOURCE: Reset Parental Control
Good day.
Try to press power up button, channel up and volume minus at the same time. This should resolve your problem.
chris
Posted on Mar 29, 2008
Anonymous
SOURCE: young son locked tv parental control
Under the main menu, go to the Parent tab and enter the Master Password: 4357. This will completely clear the present password. You can enter a new one afterward.
Posted on Mar 22, 2009
Anonymous
  • 69 Answers
SOURCE: parental controls reset
Ask Him the password. And if he don't know, just TRY EVERYTHING!!!
Posted on May 12, 2009
How do i reset the parent passcode on my daughters leappad ultra
If you forgot the parent passcode/lock code you can reset it by following these instructions: Forgot Parent Lock code on LeapPad
6helpful
I forgot my 4 diget number for my son leappad ultra how do i get wifi on for him
You can bypass the Parent Lock code on the LeapPad Ultra with this combination: 1 9 6 <backspace> 8 7
Them go to the Parent Settings menu and reset your code by tapping "Reset Lock"
Forgot password to leappad ultra tablet unable to access parent user account
Forgot Parent Lock code on LeapPad Published 07/10/2013 01:47 PM ' Updated 06/15/2015 04:11 PM
I forgot my Parent Lock code, how can I access parent settings on the LeapPad3, LeapPad Ultra, or LeapPad Platinum?If you forgot the four digit parent lock code you set up for the LeapPad3, LeapPad Ultra or LeapPad Platinum, you may retrieve the code with these steps:
1. Using a computer or other device connected to the internet, go to www.leapfrog.com
2. Click "Log In/Register" (or "My Account" if already signed in) on the top right of the page.
3. Sign in with the email address used to set up the LeapPad.
4. You'll land on the "My Account" page.
5. Click "Account Information". Directly beneath the orange "Edit" button you will see the Parent Lock code information for any LeapPad3 or LeapPad Ultra set up using this account.
Answers others found helpful
543helpful
15answers
LF.com ParentAccount instead
How do I obtain a parent code for my child's leap pad ultra? My child started the ultra before I could set up anything.
3helpful
Parental lock
the preset password is 3308. but first goto set up menu select rating press enter/play, select rating agin press enter/play, chose rating you want, then enter password 3308, press set-up to exit, press enter/play to start.
4helpful
2answers
How do you reset forgotten parental control password?
for the phillips and magnavox tv sets the code is 0711, then open the menu setting restet the code to something easy to remember , or what i would do is completly disable the child lock by going to that option in parental settings.try it hope it works!
6helpful
2answers
Parental lock
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
2helpful
2answers
Good day.
chris
Parental control
Here is the procedure to reset the parental lock code:
  1. From the XBOX dashboard screen, go to settings and then parental control.
  2. When prompted for the password, perform the following sequence using the XBOX controller: X, Y, Left Trigger, X.
  3. Enter in a new password, or disable parental control entirely.
fixya!
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
Aron
Tom Chichester
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
