Manual for sale. May want to look for similar model, or search eBay for manual or parts.
https://www.samswebsite.com/en/photofact/search/index/model/564_34401700
Service manuals and technical schematics SEARS 564 34401700 TR 62 SAMS...
SOURCE: philips High Fidelity reel to reel recorder
Shot in the dark - there is an individual who does this professionally with the Philips reel to reel - may have info for you
(BTW, do not mention that I sent you - this is a secret tip)
[email protected]
SOURCE: Repairing or replacing old tape decks
Hi m522posner
There is a surprising interest in "vintage" hifi products these days. Your tape machines probably needs new belts. Check this site out. You can get spares for your tape machine here. Belt kits are $17. He does repairs also, but the transport to and from may be an issue for you. I suggest emailing Bob, he may be able to refer you to someone in CA > I could do the repairs,but I am in Australia. :)
Vintage Electronics
P.O. Box 941
1241 Conestoga Creek Rd
Florissant, Co 80816
Email: [email protected]
You could have a go at freshening up the belts yourself:)
regards
robotek
SOURCE: play back on Sanyo mr-929 reel-to-reel tape recorder is backwards
I also have an MR-929. The information that you need is in the 'Stereophonic 4 track stereo''. As stereo is only two tracks, there is another 2 tracks in addition to the one you are listening to. Wind the entire reel to the empty spool, and then play that. As you have to physically turn the reel over to do so, you should then hear the other tracks (or track, if recorded in mono).
I use my 929 to play my parents recording of my family from the late 60s, which were recorded on a valve (tube) Ferguson machine, which had a green "magic eye" level indicator, which as a child I found fascinating!
Howie
SOURCE: My AKAI GX 636 records but can't hear anything on playback
Trace the wires from the head to the amp section. Put your finger on where they join (during playback) and see if you can get a buzz. If you can't on either channel, look for something that might be common to both channels. Either a switch, or a pre-amp IC, as being the cause of the fault.
SOURCE: Sony TC-530 hum in internal amplifier left channel.
Electrolytic capacitors are good at causing hum. You could try replacing some of them, they are not expensive. Otherwise you might have damaged the left channel amp semiconducter, whatever that might be.
