Question about Mercury Boating
I bought a 1996 Mercury 60 hp 2 stroke. I also bought throttle controls. My question is, do I have the right throttle controls. is there a schematic drawing that I can reference for htis ?
Posted by Brad Page on
Jeremy King
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
If the throttle cables are not from Mercury then you need to get the end fittings (motor side) from Merc. You dont need schematic just make sure you got the right size cables (no tight bends) Throttle controls are changeable but cables got to be for the motor. Aloha
Posted on May 21, 2018
5 Related Answers
mcgyver468
Mark L. Roberts Jr.
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
Anonymous
SOURCE: 1996 Mercury 150 Nitro EFI
Dont have the manual in front of me...recollect that there's two types of warnings. The pulsating warning is oil (starts with 30 minutes of oil left) or the fuel filter (or sperator, something like that) may have water in it. Running outboard with cover off, is a little black box that would have a red light lit if that's the case. If oil full & no red light, may be oil injection system...would also check to make sure lines aren't pinched, etc. Mine has been specific to oil the two times its gone off.
The full non-pulsating is engine overheat. Not sure beyond that.
Not much, but hopefully gets you going.
Posted on Jun 23, 2009
John Fourteen Six
  • 2418 Answers
SOURCE: impeller replacing on 1999 merc. 25hp 2 stroke
Should not be that hard. Tape up the ends so you can hold it with out getting cut, (if its ragged or sharp from damage). should be one nut holding the impeller on. If its to tight to hold try air or electric Impact wrench. If its bad you can tap with a hammer to help in removing the old one. If it turned on the shaft you will need to rent a puller. Repost if you need more help.
Posted on Jul 05, 2009
Anonymous
  • 7 Answers
SOURCE: smoking outboard
Sounds like your running a bit rich. Try leaning down your air/fuel ratio.
Posted on Aug 23, 2009
Anonymous
SOURCE: i need wiring diagram for boat 1993 Bayliner jazz
can't start my 1993 bayliner 1400 jazz. replaced key switch, kill switch today. I got the boat last week running.
Posted on Jun 12, 2010
1996 mercury 60 horse 3 cylinder 2 stroke
problem in the idle settings of the carby
could be rubber bits from deteriorating rubber hoses /water in the circuits but it needs attention from accredited mercury service centers
Apr 25, 2017 | Mercury Boating
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Jun 25, 2015 | Mercury Marine 15hp & 20hp 4 Stroke...
Mercury mariner 2 stroke 60 hp starter motor removal problems
there are 2 clamps on the starter , top and bottom 2 bolts in each ! isolate the battery then disconnect the wires off the starter and remove the clamps and starter should come off !
Mar 09, 2015 | Boating
Full throttle
check when its on full throttle that the carb butterfly is at 90deg and not over as this will reduce throttle but max advance on ignition !
Feb 11, 2014 | Seloc Mercury Outboard Engine Repair...
Mercury 60 Big Foot outboard
you can adjust the throttle position better than what you have described
the first forward action is the gear engagement and the at least 1/2 " lever movement before the engine starts to rev up
the same for reverse
that gives more control over the required rpms
Jun 02, 2017 | Boating
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
Aug 16, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
30 hp 4 stroke carburator problem
Check your "sync n link" of the throttle pick up and the ignition timing.
Aug 05, 2012 | Seloc Mercury Outboard Engine Repair...
Free Mercury Outboard ONLY, 2-40HP 1965-1989 Repair Manual 1-2 Cylinder, 2 Stroke
I have a problem with my 2 stroke 20hp mercury 1989,when I run 10-90% throttle it's works fine but when in 100% its only runs in 90% and doesn't sound normal like it's not burning right.
May 11, 2012 | Seloc Mercury Outboard Engine Repair...
Boating Logo
50 people viewed this question
Top Mercury Boating Experts
Mike
ray gallant
john h
Are you a Mercury Boating Expert? Answer questions, earn points and help others
