Unplug replug blanket to control connectors plug back in
this will continue to happen on these blankets you will have to reset these blankets again and again (chinese junk)
I had the same issue. Blinking High red light when plugged in. Tried the process above of holding power button down while plugging in and it worked on the first try!! I already replaced this one almost 6 months ago, but so glad I didn't just toss it out. Now I have a spare heating pad!! Thank you all for these helpful troubleshooting tips!!
SOURCE: malfunction heating pad
Same F2, quick off problem here. Then I noticed that the gray plug on the power cord was not completely flush with the connector on the pad. I shoved them together until there is no gap. The unit's worked perfectly since then.
SOURCE: Sunbeam Heating pad will not reset
I have a Sunbeam heating pad with the SW204 controller that the High light blinks when it is plugged in. I called Sunbeam and the first thing they said is it cannot be plugged into a surge protector. Next, to reset it unplug it from the wall, then unplug the controller from the heating pad. Wait 30 seconds, then plug the controller back into the heating pad and then into the wall. It did the trick. However, when I move it to the bedroom plug it does the same blinking. Sunbeam is sending me a replacement heating pad. They appear to be very good with Customer Service since it is more than a year old.
SOURCE: new heating pad not working
have same problem with heating pad . reset control by unplugging unit for 1 minute , while holding down power button plugged unit back in . sometimes this takes 3 or 4 tries.
SOURCE: Sunbeam heating pad no longer heats. The red
I had same issue w/ red blinking light on my Sunbeam controller SW114, pad CAT93. Was about to toss away but then got it to work perfectly by doing this:1. With unit UNplugged, press & hold the single grey controller button2. While pressing the controller button, plug the unit inUnit will power up in the 'warm' (green light) setting; pressing the controller button will cycle you thru the others modes.
SOURCE: Sunbeam dual control heated mattress
I have older sunbeam duel control matress pad. the control is simple with a dial that turnes for low or higher settings. it shows a red line that is small for low and gets thicker as the setting gets higher. there is a button for on and off. I set up the cover and turned on. the green on lite is flashing and there is no heat i do have it on high and it now will not turn off by the button.
