Question about Casio Office Equipment & Supplies
SOURCE: Set Tax rate on a Casio HR-100TM
Press the CA button twice. Then push and hold down the %/set key until the 0 dissappearsd and reappears. Then type in your tax rate and the percent key (eg: 8.25%) and then press the TAX+ key. It should save the new tax rate.
Posted on Feb 25, 2008
SOURCE: HOW TO INSTALL PAPER ROLL IN CASIO HR-8TM
There is a slot just in front of the printer
1. turn the power on
2. turn the switch to "PRINT" position
3. slot the paper in & press "FEED"
4. the paper should be able to feed up
Posted on Sep 13, 2009
SOURCE: how to reset tax % on casio HR-100tm
the 0 disappeared and reappears. Then type in your tax rate and the
percent key (Eg: 8.25%) and then press the TAX+ key. It should save the
new tax rate.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 04, 2010
SOURCE: loading paper tape
Well, I just had a long and vigerous fight withmy new HR-8TM. I came here and read all the before mentioned solutions. Then the idear struck me. Instead of cutting the paper even all the way across the roll, I cut it slanted on the sides and straight across the middle " __ " and guess what it passed the roller feed through.
It worked for me, maybe it will work for you.
Posted on Feb 14, 2010
SOURCE: THE CASIO HR-100TM HAS AN E ON THE SCREEN AND
First, check the batteries, and ensure there is not a paper jam in the printer.
If both are fine, then while the calculator is in the "Print" mode, press the [CA] (or [AC]) button 20 times consecutively to clear out memory buffers. Try some numerical calculations, and if the problem persists, repeat pressing the [CA] button 20 times.
If the problem still persists, then the calculator may require service.
http://www.casio.com/support/techsupport/AABF4C3A-D2EF-4BF5-B349-48459AF35FF0
Posted on Mar 01, 2010
Aug 07, 2018 | Office Equipment & Supplies
Jun 22, 2018 | Casio Office Equipment & Supplies
Nov 23, 2016 | Casio HR 100TM Portable Printing...
Mar 14, 2016 | Casio HR-100TM Two-Color Printing...
Feb 23, 2015 | Casio HR 100TM Portable Printing...
Jan 28, 2015 | Casio HR-100TM Two-Color Portable Printing...
Jul 22, 2014 | Casio HR 100TM Portable Printing...
Sep 05, 2011 | Casio HR-100TEPlus Calculator
Mar 02, 2011 | Casio HR-100TMPlus Calculator
Jan 05, 2008 | Casio HR-100TEPlus Calculator
792 people viewed this question
