Sound like battery problem. Maybe the battery is insufficient to hold charge (too weak).. or just defective.. TRY same battery / non generic as came with camera.
I’m happy to help further over the phone at https://www.6ya.com/expert/mike_316638c836088218
SOURCE: when i try to charge my battery the red light keeps flashing
Could be battery or charger. 1. Buy new battery. Still in trouble? 2. Get new charger Its good to have two batteries
SOURCE: Blackberry 7290 - Will not trun on
Unit is defective or the software needs to be reset/reflashed.
- J.
SOURCE: problem charging battery
it your batter light is blinking a red light then you should call up casio's technical service and they'll send you a new one:)
call 1-800-435-7732 for technical support! :)
SOURCE: Battery Charge light flashing 4 red one green Dell Inspiron 9200
usually, its an indication that the battery is nearing the end of its useful life. you can try to use another battery to isolate it further. If the same thing happens with another battery, chances are, the mobo is failing. Flashing the BIOS can usually help with battery issues. If another battery works fine and your computer is within its first year since you bought it, you can request a replacement battery from Dell
