Question about JVC Car Audio & Video
SOURCE: how to fix the offset light on my sony xplod no sound
remove the battery
Posted on Sep 10, 2009
SOURCE: Hello i have a jvc
That error message appears when the speakers wires are disconnected or shorted. This is what almost surely happened with your radio: the the wires were undersized for the power, they got heated up really badly and the plastic insulation melted away, shorting the wires.
You will need to remove the radio, disconnect the speakers and redo the entire wiring to them using thicker wires.
Posted on Jul 11, 2011
SOURCE: Hello i had a jvc
When this message is flashed up, if VALID, it most often means to check the antenna connection as it maybe faulty, or the speaker wires are faulty? Sometimes it can also indicate that the "Backup Settings" wire isn't getting power?
However, I have also seen this message when the unit itself has faulted internally, and this is just an indication of a failure.
You still need to check ALL connection to the unit, to make sure all is OK. If as I suspect they are, then this will indicate that the unit has faulted internally, usually a power supply issue, but not always.
The best thing to do, would be to take the unit to a professional, in this field, and ask them for a "Quote"as to costings for a repair. When appraised of this then one can decide what to do, repair or replace.
SOURCE: my kw-avx840 was showing a
The faulty wire was shorting on the ground. When that happened the current flowing thru the amplifier top which that wire was connected got severely overstressed. This is why the safety system was triggering. By reseting it you were just making the problem a lot worse - you were forcing the amplifier to run with its output shorted. So it was to be expected that it eventually failed - it severely overheated and it got shorted itself internally. Now it's the short in the amplifier the one that is triggering the error message. And because the short is on a critical part you can no longer reset it - the power source itself has shut down.
The radio will have to be dismantled and the failed final amplifier identified and replaced, a job for a pro - time to take it to an electronics repair shop.
Posted on Aug 15, 2011
SOURCE: my kenwood ddx616 indash keep showin DC OFFSET ERROER?
You could have a speaker wire or speaker tensile (flex) lead that is shorting to ground, on a floating ground BTL head unit (all that claim 18-25 watts RMS per channel) all 8 speaker wires are always floating at about half of the supply voltage, IE if the voltage is 14.4 with the engine running the speaker wires will all measure about 7 volts to ground.
The flex leads are the wires on a speaker that go from the terminals to the cone.
Posted on Jan 30, 2012
Feb 14, 2018 | JVC Car Audio & Video
Feb 26, 2016 | Car Audio & Video
This is normally caused by connecting a '+' or '-' speaker wire to either GND or Vcc (+12V)
1. Collect cable not being used and make sure they are tapped off and reset
2. Remove a connected cable one at a time and press RESET
3. If after a cable removal and reset the error goes away, last cable removed was fault. Examine cable for short.
4. If you remove and reset all cables except for (RED, YELLOW, and BLACK) and you stilll have error, the short is internal of unit and requires service
Aug 04, 2014 | JVC KD-R530 In Dash Stereo
MISWIRING OR CHKWIRING is displayed when there is a DC offset voltage detected at the speaker terminals ('+' and '-').
This is normally caused by connecting a '+' or '-' speaker wire to either GND or Vcc (+12V).
Apr 18, 2014 | JVC AM FM CD DET FACE CAR STEREO
Feb 12, 2014 | Car Audio & Video
Jul 12, 2013 | Kenwood Ddx719 Dvd Cd Mp3 Ipod Iphone...
Mar 22, 2012 | JVC Car Audio & Video
4,262 people viewed this question
