Question about Kenmore Kitchen Ranges
Hello LaDale,
when you do not have any information other as the brandname and the fuel type, then every one need at least pictures to find out what you want.
I wish you good luck, Dik
Posted on Apr 02, 2018
SOURCE: kitchen aid superba electric convection range
ouch thats gotta hurt!! how about the clock os that back on atleast??? sounds like a bad thermo stat on the back wall of the unit maybe a quater sized thermo 1 wire in one out, should have ( BUT DOUBt it does) have continuity through it. ifthe clock still doenst work ther is also a small inline thermal fuse connected right to the wire warness connecting to the main control
Posted on Apr 03, 2008
SOURCE: manual for kenmore electric range
I finally found a website where I could order the manual.
Thank you.
Posted on May 28, 2008
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Posted on Sep 04, 2008
SOURCE: Range door will not seal properly.
Place a hammer handle between the door and the frame at the hinges..
Push on the door, carefully.
This usually works to re-seat the door hinges.
Posted on Mar 08, 2009
SOURCE: I need a manual for Sharp Microwave/ Convection R7A85
You can download that here free.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
Posted on Aug 30, 2009
Mar 16, 2018 | Kenmore Kitchen Ranges
Mar 14, 2018 | Kenmore Kitchen Ranges
Jul 18, 2017 | Kitchen Ranges
Dec 07, 2016 | Maytag Kitchen Ranges
Sep 02, 2016 | Kenmore Kitchen Ranges
Nov 28, 2015 | Kenmore Kitchen Ranges
Oct 30, 2014 | Kenmore Kitchen Ranges
Aug 23, 2011 | Kenmore Kitchen Ranges
Jul 18, 2008 | Frigidaire Gallery GLEFM397DS Electric...
56 people viewed this question
