Question about Plumbing
I have an 4005 Am Standard "Fairbury" faucet, that is leaking out the side near the valve. Can I tighten something to stop the leak or do I need to replace o-rings and such?
Posted by Jeff Eagley on
Steve Pack
  • Plumbing Master
  • 4,331 Answers
Posted on Mar 14, 2018
5 Related Answers
pal03246
Phil Lovisek
  • 726 Answers
SOURCE: what is the valve cover torque sequence for a 2000 nissan altima
No spec for torque. Bolts have shoulders. Replace gasket. Tighten the 2 center nuts first and just tighten the rest until they stop. You can tighten one and jump across the valve cover and do the other, but not necessary.
Posted on Sep 27, 2008
Bill Johnson
  • 306 Answers
SOURCE: how to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
Posted on Jul 15, 2009
Anonymous
  • 336 Answers
SOURCE: how do you take apart the price pfister 533 50?
On the under side of the handle is a plastic plug its either red and blue or its a logo about 1/4" dia., remove that and there is a set screw that attaches the handle. Loosen that screw just enough to pull the handle off. Then you can disassemble the faucet for repairs. Price Pfisters have a lifetime warranty, if the cartridge is bad you should contact them for a replacement part.
Posted on Sep 16, 2009
Anonymous
  • 127 Answers
SOURCE: Hi Guys. My single spout kitchen faucet leaks when
spout seal kit , from what you described.
Posted on Oct 18, 2009
mikenearman
  • 127 Answers
SOURCE: I have a leaking Delta bath faucet. It?s a model
Well, even with the main valve off, the lines are still pressurized and still populated with water.
Posted on Jan 30, 2010
Do I have to disconnect the water hoses under the sink when I turn the neck counter-clockwise? I am on my 2nd replacement faucet.
You do not have to disconnect the water hoses, but you do have to turn the water valves off before loosening any parts on the faucet.
Oct 20, 2016 | Plumbing
How to stop sink leak
Check whether the faucet is leaking or the drainage is leaking.
If the faucet is leaking, you need tools to loosen the faucet to check whether the hoses are leaking or not. If the drainage is leaking, you can tighten the slip nut.
May 04, 2014 | Kohler Model 10430: Fort® Single-control...
Jameco single handle kitchen faucet with spray hard to turn
make this steps and fix it. God bless you
f a faucet leaks, replace seals and gaskets . If a shower head leaks, create a better seal or replace seals .
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type.
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes .
If the aerator leaks around the edge, replace the washer in the aerator
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head
Nov 25, 2013 | RTO Jameco #K-1320B Bone Drop In Lav Sink
The water coming out the shower jets is not powerful, help?
follow this steps and fix it. God bless you
If a faucet leaks, replace seals and gaskets .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals .
If the aerator leaks around the edge, replace the washer in the aerator .
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head .
Nov 25, 2013 | Home
Fairbury 4005 series spins by itself
call AS at 800-442-1902, they il replace it free of charge, lifetime warranty. New design for replacement faucets, will not happen again, I didnt need to send receipt or anything, great people.
Jun 02, 2012 | Washing Machines
Slight water leak from plastic drain fitting on rheem fury 40 gal gas water heater
You can try to crack it open and get a little piece of crud out of there, I'm sure that is all it is, Just get a tray or something to catch the water, It should stop it, If it gets worse, turn the water off to the heater, then open the valve and hope the bigger piece of crud comes out. It is about all you can do, other than drain the whole thing and take the valve apart and replace the rubber in it. Check it out, Hope this helps.
Dec 12, 2010 | Rheem Water Heaters
I have an american standard single control faucet. I realized water was leaking down the pipes. When i turned of the hot water valve, water stopped leaking. How do i go about fixing this.
Chances are your supply line is leaking. One of three things (easy fixes).
1) There is a "packing nut" on the shut off which holds the handle on - this could be leaking (just tighten with pliers while open).
2) There is a nut directly above the shut off (3/8 inch) which goes directly to the faucet. Simply thighten this nut.
3) There is yet another nut above the last (very near the faucet). This is a 5/8 nut and you will most likely need a "crescent wrench" to tighten this as you cannot get pliers up there. You can purchase a crescent wrench at any hardware store for about 10 bucks. Good luck!
Dec 30, 2009 | American Standard Kitchen Faucet 6310 020...
Repair leak on jasmine faucet - American Standard
you need to replace the 0-rings in side the spout between the base and neck,
Jun 13, 2009 | American Standard Jasmine Mixage Kitchen...
Plumbing Logo
540 people viewed this question
Top Plumbing Experts
Bill Johnson
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
