It appears that the water heater has 2 elements but on 1 thermostat, I would hope that there is an upper and lower thermostat . If water heater has just been installed the cold water feed is hooked to the hot water discharge, Cold water to cold hot to hat. They are marked on top of unit..Or the unit was powered up before tank was fully purged. If there is only 1 thermostat Shut power down and using a DMM check resistance on upper heating element and compare to lower. If the element is damaged it will show a high resistance. You can buy replacement elements, at box stores.
https://hw.menardc.com/main/items/media/RHEEM001/Install_Instruct/StandardElec_UC.pdf
SOURCE: i have a richmond gas hot water heater model
resetting your lock out for richmond power vent
SOURCE: 50 gal. Reliance electric hot water w/bottom element problems
Willard when you say it throws the reset button,do you mean the breaker on your fuse box of your home?
If you mean that then yes it could be a bad element.The bottom element takes all the abuse on a electric hot water heater. They can short out,and need to be replaced.
SOURCE: New hot water heater cause smelly hot water.
U can clorinate ur water heater 1 gallon will do it. But you should try changing the anode rod(to aluminum) or removing it first followed by a complete drain, purge and refill.
SOURCE: how do I change the
Buy elements at local hardware store or home center, like Lowes
Look at label on side of tank.
Label shows element wattage.
Element is also printed on end of element in tiny letters-numbers.
Typical elements are 4500 and 5500 watts.
Tank needs 10 gauge wire and 30 amp breaker for 5500 watt element.
Water heaters are fully repairable by homeowner.
1) Have you tested water heater to see if element is problem? You need cheap multi-meter from Home Depot.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
2) To change element
a) turn off power
b) drain water from drain valve ... once it starts draining, loosen element slightly while tank still has weight to hold against you turning element wrench.
Here's what to do if water heater won't drain:
http://waterheatertimer.org/Water-heater-will-not-drain.html
c) open covers on tank, remove element using element-wrench from hardware store or home center.
If element won't come out:
http://waterheatertimer.org/How-to-remove-old-water-heater-element.html
d) Clean out tank if needed.
e) Replace element.
f) Fill tank entirely with water before turning on power or element will burn out.
g) Once tank is filled, and water flows steady out of tub spout, turn on power.
Each steps above is shown on following link:
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
3) You need to buy some things:
Screw-in type (not bolt-in type) Element that matches wattage on tank label. New Element comes with washer.
Inexpensive Element wrench.
Inexpensive multimeter if you are going to test parts first.
Some pieces of pipe and hose if tank sediment needs to be cleaned out.
Washing machine hose if tank will not drain (return after job is done).
4) Also:
You need flat tip and phillips screwdriver.
Lighting to work on tank
Some WD-40 if element is stuck in place.
Garden hose to drain tank.
Shop vac and duct tape if you need to vacuum out sediment.
Tarp to protect floor and carpet
Maybe a knife to cut back insulation on wire if wire is burned at element.
Web links above go through entire process step by step.
Add a comment if you need more help, I'll be back around 5 CST
SOURCE: My Rheem: Model # 41V50,
The drain valve can always be replaced so you can drain that with no worries....after it is empty open and clsoe the cold water valve to flush more...
As far as being large enough... that depends...
If you have a teenager like I do that takes 40 min showers in steaming hot water... no....
If you are running more then one shower at a time... then probably not...
The other thing that could have happened is that the dip tube for the cold water inlet has broken off or disintergrated...that happens...
Usually you will then get cold water and the gas valve will not yet have kicked on the burner, because the cold water is not going to the bottom...
If it is a new install... check thet the supply and return are hooked up correctly...
thermostat is gas vavle may also be bad, but not too likely...
heatman101
Testimonial: "Thank you for your information. I will try to drain the tank first."
