SOURCE: Panasonic Microwave Warm
Replace the h.v. capacitor (the silver can mounted in back under the magnatron) and the h.v. diode and it will be fine.
Hope Ya Fix It!
SOURCE: Panasonic Inverter NN-V673S microwave- shuts off after 2-30 secs
If the screen is showing a fault number or a number you havent seen before then its probably a program fault which can't be fixed. Check that the vent holes on the back of the oven aren't dirty and ensure that the whole oven is clean inside. Sadly it sounds like a program fault which cant usually be fixed by the owner though.
Finding a Panasonic oven repairer in the UK shouldnt be a problem though. My parents had a simlar problem wth their Panasonic Inverter oven, called the UK customer services and Panasonic contacted an authorised repairer in Scotland to visit them. Call customer services on 0844 844 3868.
If the call out charge exceeds £80 then you're probably better off buying a new oven.
SOURCE: panasonic inverter dimension 4 microwave
If
it stops after 22 seconds, that means the controller has detected a
problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
SOURCE: My Panasonic Microwave Genius 1300W will not heat
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven.
Most people don't, for this reason, replace the magnetron, they replace
the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the
magnetron is faulty and you need to take it apart, find the proper
electrical leads and test them with a volt meter. To do this you have
to remove it from its mounting and take it apart. It is a fairly
lengthy process however.
Benjamin
SOURCE: Panasonic Microwave NN-A770S getting hot on right side externally
Is it normal for a Panasonic nn-c994s to cycle the fan/inverter
when using combination cook?
16 sec off 6 sec on.
Everything else seems to be working
light, timer counting down, heating food, turntable turning
