Question about Dell Computers & Internet
Dell Latitude E6410 LCD Panel unable to turn lamp on Error code 0326 screen goes blank after booting on hard drivel Works fine booting on DVD or USB. See Windows symbol, opens blank screen. Diagnostics: LCD Panel unable to turn lamp on Error code 0326 diagnostis
Okay this is common with that old laptop the problem is usually the lcd inverter i attach a tutorial video for you to see and understand what it is.
this part produces the high voltage required to light up the screen and burn out it is under the actual screen below the plastic bezel which is held to gether by screws under little plastic covers locate at top left right and lower left right of the screen Dell Latitude E6400 LCD Inverter Replacement How To Tutorial
Posted on Mar 13, 2018
SOURCE: Dell Latitude D800 Boot Problem
Did the diagnostics pass the RAM and the hard drive.
You should check the BIOS settings to see if the hard disk is detected, if possible reset the BIOS back to the default settings and see if the computer boots up.
If not :-
Then it appears that the operating system is either corrupted or system files were deleted or infected with viruses.
Your only option is to do a operating system repair or a complete new install of Windows.
I recommend you do a new install.
Posted on Nov 23, 2008
SOURCE: XPS 600 BIOS setup problem
light 1&2 is a memory configuration error.make sure you have the memory in correctly
Posted on Jan 18, 2009
SOURCE: Strike F1 key to continue, F2 to run the setup utility
Please let me know what is the make and the model of the pc that you are using.. Also, go to the bios, under boot menu, make sure that you have hard drive as the first boot option.. For further queries please get in touch..
Posted on May 28, 2009
SOURCE: Dell Inspiron 1526 cannot communicate with battery
The diagnostic Error is a False positive you can ignore the diag error as the LCD is functional. If the battery is not recognized in the BIOS or you get an warning the AC adapter is not recognized, then you may have either a damaged AC adapter sensing pin (Fine wire in middle of ac adapter connection to Laptop) or a problem with the charging unit on the motherboard.
If the sensing pin is damaged or the ac adpater is not sending the right signal to the system, the battery charger will not work. SO if you have another Dell D series AC adapter, you can try it 1st. If the battery is 18 mos to 2 years old, you might see if it is IDs in BIOS and if it indicates battery state. Also the battery should have a test button and 5 LEDs on it. If the 1st 3rd and 5th LED flash the battery is bad. ANy any come on solid, then it is a % of charge, each LED = 20%
If you end up replacing hardware, then it will most likely be in this order:
AC Adapter, Battery, Motherboard
Posted on Jun 04, 2009
SOURCE: Dell D630LCD inverter error, unable to turn lamp ON/OFF.
hi,
the interal graphics adaptor is making trouble, to find aóut if it just with your screen, hook up another external monitor and boot up.
Still the problem?
then you wil have to (let) the graphics card (be) replace(d), definitely.
Good luck
Posted on Sep 07, 2009
