Question about Motorola Radio Communications
I want to know if i can pair my samsung galaxy victory sph-L300 to a motorola H500 bluetooth?.
Posted by Ben Cummings on
5 Related Answers
Bajanguru
Sylvester Brathwaite
  • 7752 Answers
SOURCE: Bluetooth H500
when it asked for the pincode to paired the bluetooth headset enter the code 0000
Posted on Jan 20, 2008
Anonymous
  • 3 Answers
SOURCE: Bluetooth Pairing
How you doing. the code to connect this divice is 0000. all codes are the same and CANNOT be changed.. Good luck
Posted on Oct 29, 2008
Anonymous
SOURCE: cell samsung SGH-F250 with bluetooth motorola h500
ACTIVATING THE BLUETOOTH
You must activate the Bluetooth feature of your phone to be able to establish a Bluetooth connection
between your phone and your SuperTooth kit as well as with other Bluetooth devices.
1.
Press Menu > Settings > Bluetooth > Activation > On.
2.
Press Back as many times as needed to return to standby mode.
PAIRING TO THE CELLULAR PHONE (Not possible while charging the SuperTooth)
Pairing will create a link or connection between the two Bluetooth devices - the SuperTooth kit and your phone.
1. Bring the cellular phone at about 20 cm from the SuperTooth.
2. Turn off the SuperTooth and wait for about 4 seconds.
3. While pressing the Answer Button, turn ON the SuperTooth by sliding the Power Switch to the right. Keep the Answer Button pressed for approximately 10 seconds until you hear a distinctive tone and the Bluetooth indicator LED changes from blinking blue to alternately blinking of red and blue. The SuperTooth is now in pairing mode.
4. While the SuperTooth is at pairing mode, access the Bluetooth menu of your phone. Press Menu > Settings > Bluetooth > My devices > Search new device. The phone will then search for pairable devices until it displays them in the list.
5. Highlight SuperTooth then press Select.
6. Enter PIN “0000” then press Ok. (Wait until “Paired with …“ and “Connected” will be shown briefly.)
7. Press Back as many times as needed to return to standby mode. Pairing is successful if the alternating red/blue lights of Bluetooth Indicator stops and then change to plain blinking blue. Normally, the phone would also show briefly on its display if it’s already paired and connected to SuperTooth or if pairing with it failed.
The SuperTooth kit is now ready to use.
Posted on Mar 13, 2009
Anonymous
  • 18 Answers
SOURCE: problems pairing up a Nokia 6301 with my Motorola H500
Try power cycling the phone. Turn the Nokia off, wait 10 seconds, then turn back on and try again. It really does help sometimes. Let us know if this doesn't help.
Posted on Sep 06, 2009
Anonymous
SOURCE: pair motorola H500 to samsung eternity SGH-A867
I have had this problem too. Here is what worked for me.
1) With the Motorola H500 OFF, press and hold the talk key until you see a steady, non-blinking blue light.
2) Keeping that button pressed, turn on the bluetooth on the samsung eternity.
3) It should now find the H500, click on it and select connect.
4) Put in a pass key (I just put in 0000) and your done.
Posted on Oct 28, 2009
Problems pairing up a Nokia 6301 with my Motorola H500
Apr 01, 2009 | Motorola Mobility H500 Wireless Headset
Pair motorola H500 to samsung eternity SGH-A867
Mar 06, 2009 | Cell Phones
Lost phone that was paired with the H500 - need to re-pair
did not need to unpair. Just needed to have phone search and use 0000 code.
Feb 28, 2009 | Motorola Mobility H500 Wireless Headset
Cell samsung SGH-F250 with bluetooth motorola h500
1.
2.
Nov 15, 2008 | Motorola Mobility H500 Wireless Headset
Communication problems with Motoroala H500
i have a h500 cannot pair with my phone lg env
Aug 01, 2008 | Motorola Mobility H500 Headset
Motorola H500 not able to connect to Vista
I had the same problem w my Compaq Presario V3000 HP BT module. I installed the HP Bluetooth drivers from hp.com and that fixed it. So instead of using Vista's built in stack, try one that your manufacturer may have issued.
Pim from the Computer People
Helping Kiwis go places
Ph. +64210398346
Apr 29, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Bluetooth H500
Jan 02, 2008 | Motorola Mobility RAZR V3
Bluetooth
Press the all-in-one button for about 8 seconds until the light is constantly on, this puts it in pairing mode. then go to your device and initiate pairing. the device code is 0000.
When done the blue light should shut down, and your all set.
Nov 07, 2007 | Motorola Mobility H500 Wireless Headset
Radio Communications Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
