My Toshiba washing machine model AW-A800MBK This have 4 LED lights, Now machine running some time drain and showing LED 2,3 glowing and then machine stop, What is the problem with this machine?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 721 Answers
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
Posted on Mar 13, 2018
6ya staff
SOURCE:
rallyb33
  • 6 Answers
SOURCE: I have a Kenmore Elite Oasis HE washing machine
could have a blocked drain/ coin trap. Look under the washer behind a panel or in the back. You may have to take out screws
Posted on Oct 23, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: Toshiba auto washing machine model
Hi.
E2 is not an error code. It means that the Spin only mode has been started and that the cycle is now over.
To reset the machine try disconnecting power (trip circuit breaker), connecting back, then hold down the Super Spin Dry button while you start the machine at the same time (press On while holding the other button). You should hear three beeps and the machine will be reset to initial settings.
Posted on Feb 01, 2011
noman_raheem
SOURCE: I have a Toshiba Washing
aoa may machen is toshiba problem is timer not work and led blinking you gev meen anser waht porblem hai thanks
Posted on Jun 09, 2011
syd_2811
SOURCE: my AW-1170S toshiba washing machine
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Posted on Aug 28, 2011
gbob59
  • 3042 Answers
SOURCE: toshiba washer malfunctioning model aw 9770 sb showing an error of e7-4
Owner's manual troubleshooting may give you an answer.
Google make model possibly serial year. You may find someone with the same problem and the solution. Usually MFG customer service is helpful. If fairly new local dealer may be helpful.
Posted on Mar 08, 2015
Hello sir my Toshiba washing machine model no. AW-AD1500WUBB error Ed
That code means extended drain. It is taking too long to empty the water. Check the pump and drain system for items that may be plugging it.
Aug 04, 2018 | Washing Machines
Toshiba washing machine When I push on the error E7-4 shows and then it turns off what is E7-4 error ?
Is your machine either the Toshiba AW-SD120SM or AW-SD120SS?
If it is I checked the manual and the error code you mentioned is not listed in their operators manual. On page 35 of the manual there is a message that says "As for information display beyond the above-mentioned details, or the above-mentioned solutions do not work, please disconnect the power plug and contact technicians for repair."
The only codes mentioned are: E1 E21 E23 E31 E32 E5 A ans F
Jul 31, 2016 | Washing Machines
My toshiba washing machine aw-9500 SB showing error E9. what is the solution???
Check that the level of the drain hose is not lower than the base of the washing machine. Additionally check for a water leak. If no trace of water, switch off the power, reconnect and try again.
Jun 10, 2016 | Washing Machines
E2 error code aw-8990st toshiba wash
E21: Lid open
E31: Load imbalance
Hope this helps
Jan 25, 2014 | Washing Machines
Toshiba washing machine AW-1160SM error E7-1
my washing maction have a priblem E7 err
Jan 11, 2012 | Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
Nov 13, 2010 | Washing Machines
Washing Machines Logo
644 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
