SOURCE: EXCEL SPREADSHEET FOR INVENTORY
Dear pauline, you can link cells in formula bar to see immediate effect of additions and subtractions in dependent boxes.
Like for example you add three numbers in three boxes A1, B1, C1 and answer is supposed to go in D1, just type =SUM(A1+B1+C1)
in D1.
now when you will change the values of a b and c boxes, the value of d1 will automatically change. for adding more numbers you can leave boxes empty so that you can fill in later to see the change in the sum box.
please press fixya if that has helped you.
SOURCE: Formula required
On sheet 4, select cell A1 and press "=" (don't press enter key).
Select the sheet 1 tab and click on the cell at the top left corner of your sheet 1 data. (dont press enter yet.) Press the "+" sign and then click on the Sheet 2 tab. Select the cell on sheet 2 at the top left corner of the data table on that sheet. Now press "+" again. Now select the sheet 3 tab and select the top left corner of the table there. Finally, press the enter key and you will be back on sheet 4. Cell A1 on sheet 4 will show the sum of the first cells of the tables on sheets 1-3.
Here's how to copy the formula on sheet 4/A1 to the other cells:
Select cells A1:A12 on sheet 4. (in other words, highlight all the cells that will become the top row of the table on sheet 4.) Now press Ctrl-R. This will copy the formula in cell A1 to all the highlighted cells to the Right of it. Finally, highlight the area that will become your table on sheet 4 (12 colums, 10 rows). Press Ctrl-d. This will copy the formulas in the first row Down to all the cells in the highlighted area below.
SOURCE: adding and subtracting lengths of measurements
You can use the units menu (2nd > 3) to place a unit after some number you want to qualify as being an unit, or you can just type them in like 5_ft + 6_in. Note that you need to add on each part if you are doing mixed measurements; there is no _ft_in combination. So just add each manually - in your case you would do (5_ft + 6_in) - (2_ft + 8_in)
SOURCE: I have an assignment where 4 worksheets were
I'd say you need to pay better attention to the Excel or other spreadsheet books and help you have handy, and categorize your problem according to the behavior you get inconsistent with the suggested solutions already available.
No excuse for your laziness!
Formulas are used to specify calculations based on values in designated cells. Excel supports basic calculations as well as statistical, trigonometric and other specialized functions.
Formulas used in Excel must follow a certain syntax.
