SOURCE: VW temperature display
The sensor for the temp display in located in front of the radiator under the hood, it is round and has 2 wires going to it, plug and unplug it a few times and recheck to see if the display works, if not replace the sensor.
SOURCE: OUTDOOR TEMPERATURE
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
SOURCE: outside temperture
Try changing the batteries in the CLOCK. I had the same problem in a 3M similar clock and it didn't read the transmitter correctly or eventually, at all, when the CLOCK batteries were getting low.
SOURCE: Outdoor transmitting
These devices have a limited range, normally 20-30' (~6-9m) and that range is influenced by the material that separates them. Any metal structures in their path can shorten the useful range. Also, I think all of these transmit only a second or two every few minutes to conserve battery power.
SOURCE: i threw away the entire stand... now i need it back
This is the best place to get at a good price.
http://www.shopjimmy.com/catalogsearch/result/?q=polaroid+stand
You'll have to check from time to time for stands in stock.
