Product: Polaroid i1236 digital camera, Model No: CIA-1236B
SOURCE: sanyo digital camera model- vpc5500
Playing Back Movie Clips
You can play back the recorded movie clips on the LCD monitor screen. However, the
sound recorded with movie clips can only be played back on a computer.
1. Press the button.
2. Use the four-way controller () to go
through the images until the movie clip you
want to play back is displayed.
To view the previous image, press the
four-way controller ().
To view the next image, press the
3. Press the button to start playing back
the movie clips.
To pause or resume movie playback, press the button again.
SOURCE: My new i1236 Polaroid digital camera will turn
1) The card could be write protected, check the side of the card see if there's a small notch to slide up or down.
2) The camera could have photo protection option switched on, you have to go through the user manual and the camera menu to switch that off.
3) If you don't get too far with the first options, as its new, take it back to the vendor and ask them to demonstrate it to you and to your satisfaction. If there is a problem with the camera, request a replacement or refund under warranty.
Testimonial: "Thanks for your help, I'll try it."
SOURCE: Which user manual addresses the
Your vacuum cleaner is not a problem. An Oven usually has a wall installed fuse and mains switch, don't know what the EU recommends but in the UK the vacuum cleaner doesn't usually have such a close relationship with an oven unless it is sucking hot air.
