Question about Blaupunkt Televison & Video
What connection cables do I need to conect to a sky box to my blaupunkt tv
Posted by Lesley berry on
antoniorojas
    Dedicated:
    Visited the website for 20 consecutive days.
  • 280 Answers
Almos all of them 3.5 rca plug, hdmi usb etc...
Posted on Apr 27, 2019
5 Related Answers
chrispurs1
chris pursloe
  • 372 Answers
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Posted on Jan 31, 2008
SOURCE: Connecting Sky TV to my projector
Which connectors do i need for Sky + to a Hitachi CP-X340 Projector
Posted on May 29, 2008
Anonymous
  • 3 Answers
SOURCE: Connecting the LE46A556P LCD TV to the HTZ310R Home Cinema System
You need to be connecting the TV and the Sky Plus to the HT box via optical (toslink) for full surround sound. As you only have one optical port on the HT, I would suggest buying a Optical selector such as this one. I would also suggest looking on avforums more more help. I use it for most of my questions if ever i need any help.
Hope this helps!
Posted on Jun 01, 2008
fahadn
  • 21 Answers
SOURCE: No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Posted on Sep 14, 2009
Anonymous
  • 85 Answers
SOURCE: I have an LG TV
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Posted on Jan 07, 2011
I have a bush tv and I can put 1 him cable in to connect my sky had box but when I try to put a second one in for my ps4 it's say hdcp is not supported can someone help.
Try fitting cables in a different orderor swapping the working sky conected cable to the ps4 cable. I have several hdmi and scart cables into my LG tv. Sorry but can't help more as I don't have sky or a ps4
Oct 28, 2015 | Bush Televison & Video
Could you please tell me if my LC-32GA5E tv can work with sky HD.The manual tells about switching to hd mode,but there seems to be no where to connect hd to the set.The tv is about 5 years old. thanks...
This is an HD ready TV and can definitely be used with Sky HD, but ONLY if the Sky box is connected to the TV with an HDMI cable. It will not work if connected with a scart cable.
So you need 2 things. Firstly, you need to buy an HDMI cable (see picture) if you haven't already got one. Secondly you need to locate the HDMI sockets on your TV and Sky box. The sockets will have the HDMI logo (see picture) next to them.
Oct 16, 2010 | Sharp LC-32GA5U/LC-32GA5E 32 in. HD-Ready...
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
May 08, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Samsung tv 32:inch no LE32R74BDZ WILL NOT WORK WHEN CONECTED WITH HMDI CABLE ,SCREEN GOES GREEN. SO I USE COMPOSITE CABLES .I HAVE A FOXSAT HD SKY BOX. BUT I WANT HD PICTCURES. AS I HAVE AN HD BOX . IS IT...
We need to narrow things down . If you have a dvd player that has an HDMI output plug that into the HDMI input of the tv with a diffent cable than the one for the sky box. If color is still green then the main board on the tv is bad. If the picture is good then Either the cable used for the sky box is bad or the sky box is bad.
Mar 25, 2010 | Televison & Video
I WANT TO BE ABLE TO SEND SKY TV SIGNAL TO ANY ROOM, i HAD THIS IN OUR LAST HOUSE BUT CAN NOT REMEMBER HOW i RUN ALL THE COAX CABLES. i HAVE AN APLIFIER IN LOFT WHICH CABLES TO EACH ROOM, SO DO i NEED TO...
put coax from sky box output then into splitter in loft ampifier and conect all other coax that run down to other rooms to the outputs in amplifrer and turn on sky and put menu on then tune tv's in on anolog station
Dec 20, 2009 | Panasonic TH-42PX60U Television
How do I retune my Thomson Digital TV 24WK25UG after digital switchover in Granada area
this tv is not a dtv tv you can only watch digital tv if you now have a freeview box this is conected via a scart lead . you select av on the tv remote . or you can watch sky or cable . these are connected the same way .
Dec 04, 2009 | Thomson 24WK25U 24" TV
How do I connect my sky eye? It arrived with no instructions and I am not sure what i need to do! I have a sky box in one room and now the sky eye connected to my tv in the other room - does it plug onto...
You need an aerial connection between the two units,the aerial will plug into the eye and then the eye into the tv.The cable connects into your sky box in the one marked output 2.You then need to go into service`s on the sky box,select 4,then press 0 1 select,goto rf output and turn on.
Nov 11, 2009 | Televison & Video
I have just bought a Sony DAV-dz260 home theatre system. I connected it viz HDMI to my 1080p tv and it works fine. I also have a Sony PS3 connected via HDMI to my TV and this works fine too. I have...
i have the same dav dz260 and all my stuff works on mine. this is how i set it up i have conected y dz to the tv via scart and my sky and ps3 via hdmi cable. to get sound from sky and ps3 i conected a optical cable from the dz260 to the tv and when i want sound for sky or ps3 all i did was change the function on the dz260 to tv and the tv setting to the hdmi im using and hey presto sound hope it helps
Nov 11, 2008 | Televison & Video
Connection advice needed
hello.on that samsung you probably have more than one hdmi conection so conect your dvd/vcr with hdmi cable to tv and sky box with hdmi to if its have hdmi or with scart if not.if you still have problems with conection,make some photos of tv,dvd/vcr and sky box all back panel and send to me ([email protected]) and i send you the best solution i can.
Aug 14, 2008 | Samsung Televison & Video
Televison & Video Logo
Top Blaupunkt Televison & Video Experts
Marvin
Marvin
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Blaupunkt Televison and Video Expert? Answer questions, earn points and help others
