Question about Sharp Televison & Video
Hello All, My Sharp Roku tv, LC-50LB371U, screen went dark. When turned on I heard the chirp sound but no picture. This unit has a main, power and IR board. Any suggestions as to the likely culprit? Thanks much. The issue is not the cable box as another TV when connected to the cable box produces both sound and picture.
Posted by Andrew Hepburn on
  • Sharp Master
  • 18,438 Answers
YOu have a bad led back light, they come in strips and are a pain the bottom to find and replace.
Posted on Mar 11, 2018
  • 1 more comment
  • Andrew Hepburn Mar 11, 2018
    Thanks Brad, I suppose it's best to just recycle it.
  • Brad Brown Mar 12, 2018
    http://www.shopjimmy.com/catalogsearch/r...
  • Anonymous May 12, 2019
    This may help the others, 50lb371u has 3 sets of 22 leds in series. These 3 sets are individually supplied with 64 vdc or 65.5 vdc in my case. 2 sets of leds are connected to +VLED1 and -VLED1 while the other one set is connected to +VLED2 and -VLED2. Each led is powered up with 2.9 to 3 vdc forward voltage, so if the ouput voltage coming from the power board is 64 to 65.5 vdc this should be correct and the issue is most likely the led that could be shorted or open. See attached picture
5 Related Answers
Simpson Neal
  • 236 Answers
SOURCE: tv went dead while viewing, will not power back up
You have a short somewhere in the load for the power supply. Probably the horizontal output transistor and the flyback transformer. You need to have it checked out by a tech. You may want to get an estimate. Stargazer
Posted on Mar 11, 2007
Azrael SRL
  • 11800 Answers
SOURCE: sharp lc-19sb225u tv turns on with a "white noise"
The blue screen means the processor of the tv no longer finishes the loading of the firmware - hardware fault, either the chip that stores the firmware or the processor have failed.
Since the chips are soldered on the mainboard and cannot be removed separately that means that the entire mainboard will have to be replaced. This is it
http://www.partstore.com/Part/Sharp/Sharp/LC19SB25U/Sharp/Sharp/DUNTKE352FM02/New.aspx
Now you must decide if it's worth paying $400 for a replacement board or it's better just to buy a new tv - i'm for the second option.
Posted on May 17, 2011
SOURCE: sharp Lc-26sb24u white screen with sound
You will get a white screen when you unplug the t-con from the main board. Doing so removes power to the LCD panel. Verify that all of your voltages from the power supply are correct. If they are, I'd look at the t-con board. It sounds like there is a problem with the t-con that is pulling down the main board.
Posted on May 11, 2012
Subair Achath
  • 181 Answers
SOURCE: Sharp Aquos 55 inch LC-55LE643U LCD TV - When turned on fades from Black to White - Still have sound. Do I need a Tcon borad or main board? Has power so I assume power supply is ok. Thanks
Check all source is same or not
Try factory reset.
Posted on Aug 02, 2016
My Sharp Roku TV model LC-50LB371U Has no picture, no audio. When I shine a flashlight on it, I can read "Comencemos"
it means "lets start" in Spanish, but you might want to change/check the LCD backlight & inverter first. ;-)
Good luck.
Nov 24, 2017 | Sharp Televison & Video
Sharp LC-50LB371U TV won't turn on but red power light comes on but no screen or display. The power board has no visible capacitor buldging. Any advice on which board may be bad?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 23, 2017 | Sharp Televison & Video
Sharp TV (LC-40LE550U) without picture, but sound is fine. Very weak image with flash light. TV can be turned on with remote with green indicator.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
Feb 29, 2016 | Sharp LC-40LE550U 40" LED TV 1920x1080, 60...
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Jan 05, 2010 | Sharp LC 37D62U 37 in. LCD HDTV
Sharp model lc19sb25u sound and no picture screen
Part called main unit failed and require replacement. part number duntke352fm02.
Oct 08, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Sharp Aquos wont turn on
this is either a power problem or the screen needs re-gasing
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
3,313 people viewed this question
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
