SOURCE: Dryer door pops open after
door strike is bad also door may be warped make sure door is not warped if it is just twist in opposite direction if strike needed part #279570
SOURCE: ELectrolux frontloader EWF1090 door wont open
Make sure you drain the machine first by setting a spin cycle manually and see if it releases the door after a few minutes. If that fails then switch off the machine and leave for 5 mins, door should release but you could end up with water on the floor. After this clean your filter and check you water pump, then try a short cycle without clothes.
SOURCE: adg450 about 5 yrs old. Beep Beep.....Beep
Hi, I have a very simular problem, I have just read that running the water in the kitchen sink until its hot may work, if not could you please let me know if you get an answer to this problem,
Thanks
Peter
SOURCE: I have front loader dryer and the door is popping
Buy door latch kit from parts supplier. Comes with male and female parts of latch. Replace female part first and see if problem correct. Replace male if necessary. Don't worry if parts break off and fall inside while removing old pieces.
Kit is very inexpensive. If after replacing both parts your door still pops open check to make sure door is not sprung. To do this place a known straight edge across center of door from left to right and be sure there are no gaps between door panel and straight edge. If no gaps, replace hinges. They are likely bent.
I appreciate your post, kris!
From what you have explained your Electrolux dishwasher is beeping three times every four to five seconds. This could be a possible issue with your control panel. It may need to be replaced and this may not be a simple DIY job. If you need assistance locating a professional I would recommend reviewing your manufacturer's website for help. I hope this information is helpful for you. -Matt
