Question about Video Game Consoles & Games
Change language on vmu for dreamcast - Video Game Consoles & Games
Posted by Crystal Primor on
My control wont work
did you tested another dreamcast control...you had the same problem...so you have to check the protection Fusistor inside your dreamcast conector controller board....it seems like a blue or green normal resistor...marked as F1 on the board..change it with a simple fuse or an smd fusistor...Good Luck!
3answers
Dreamcast black and white
it could be the cables or even the tv
I just got a brand new cable for my dreamcast but i still have no picture. The problem seems to be internally. What should I do?
the problem might be in the Dreamcast its self or the tv you our using. try connecting it to a another tv and see if that works. If it dosent it is the Dreamcast and i have no idea were you will get another one exept on ebay.
Dreamcast displays visual, but it is darker than usual
Generic problem in dreamcast. Is a resistance failed in the bottom of motherboard. If you know how test it, you can change it.
I have a sega dreamcast but i can't change the date. what can i do. do i need f1 fuse.
At first mine would do the same thing, so I thought. What you should try doing is go to "settings" and change the date, then go down on the list and change the memory card date settings. If that doesn't work then I'm really sorry I wasted your time.
Freezing problem with Games
The Dreamcast is no longer supported because it was to easy to copy the games, but there are still a loyal few who keep the scene alive. I have no idea how much you want to put into fixing the problem, but the only way to fix your problem is flashing the Dreamcast BIOS.
Modification 101:
http://www.youtube.com/watch?v=v7v8cEU1I50
The Dreamcast is basically a computer; with the right programming you can do anything; and having a Dreamcast Keyboard is nice.
Other links you should check out...
DreamChip and 4 in 1 Connector
Another Dreamcast Mod Chip
The Ultimate Dreamcast Survival Guide
Sega Dreamcast VGA Mod
Modified Dreamcast BIOS
www.dc-scene.net
I cannot work out how to change my personal message
RH key
Operat
Password - OK
Expert
RH key
VMU
GalMbx
Record
Record
6answers
Dead controlers
Buy a new one and get rid of your sega and get a xbox.
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
Aron
Tom Chichester
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
