I have a panasonic top load washing machine, when its finish washing cycle, drainage the water & going to start rinse, it stops & shows alarm u11 , if this alarm for Abnormal water level sensing, Is it means pressure level sensor or hose needs to replace , and is there any other reason cause this problem?
There should be a LOCK ICON with an LED to tell you whether the Front Load door is locked or unlocked.
If the machine door wont open after the wash cycle, the dryer function or the drainage function hasnt completed.
What you can try is just choose the dryer function after the completed wash cycle if the problem arises again.
IF that doesnt work, then look at bottom of the machine; there should be a flap present which you generally open up to get to the manual drainage valve.. you just pull that open and drain any leftover water .. After the water recedes.. the LOCK icon should be off and you can then open the front load door
Unscrew the back of the machine to look and see if there is any water in the base of the machine. How old is your machine? If it's new I'd exchange it for another one like the LP or even Mag tag- It's not easy to fix these machines and finding the real problem is sometimes a night mare. The Panasonic error codes are difficult to find, but 'H' faults are generally faults which may or may not be repairable. Like the sump pump -or motor. The other codes are like this: U11 indicates machine unable to drain. Blockage between drum and drain pump?? Blockage of drain hose??
U13 indicates unbalanced load. Many modern machines suffer from this, but may be related to problem causing U11 fault.
H43 indicates an internal water leak reaching its detector in the machine base.
Like any washing machine, they are great until they go wrong. The problems are usually related to the after sales service.
I hope something helps here-just my 2 cents worth!
Your Maytag Neptune Washing Machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle. Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked. 1.Check wire connections in harness leading from machine control board to door lock mechanism.2.Check solenoid and door lock enable switch in door lock mechanism. 3.Replace responsible component.
Front Loading Washing Machine: Fully automatic. 1. Better washing than toploading as technologically proofed. 2. No extra effort except putting cloths and detergent inside.3. No need to observe
in between while washing.Start and forgot. You can go market and come back. 4. No issue if electricity or water went out during washing. 4. Take more water compare to toploading semi-automatic. 5. You can not open it once it started.
Top Loading Washing Machine: Semi 1. Save water and detergent. 2. Need extra effort to put the cloth from one box to another.
Front Loading Washing Machine: Fully automatic. 1. Better washing than toploading as technologically proofed. 2. No extra effort except putting cloths and detergent inside. 3. No need to observe in between while washing. Start and forgot. You can go market and come back. 4. No issue if electricity or water went out during washing. 4. Take more water compare to toploading semi-automatic. 5. You can not open it once it started.
That code (5E, not SE) means the drainage is clogged. The code appears after 15 minutes of trying to drain the tube (not sure that´s the word, may be turbine, barrel...). check the lateral filter (a big plastic twist-off cap) for any solid that may be clogging the drainage
