SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
SOURCE: Altec Lansing speaker - model ada 745
I am guessing you mean the cord that goes into the PC, I don't know how "Broke"it is, but you should be able to cut the old end off and replace it, if you buy an inexpensive speaker extension cable, you can use that for the new end, or try radioshack, they may have replacements that just need to be wired, usually a black and red wire is all, just tape it up good to avoid shorts
SOURCE: Problem with Altec Lansing ADA 885 Computer
check u have the lastest sound driver.or u can try uninstalling it and run driver cleaner then try reinstalling driver.if u are using vista u may have to go to audio devices and set from there.also try air the input plug whole just incase dust has settle there. hope this helps.
dt
