Question about Food Mixers
I have a kitchen aid stand mixer. model #rkt2651x. it goes very fast when turned on then shuts off. it will go again but turns right off again. age?
Andrew Taylor
    Top Expert:
  • Food Mixers Master
  • 34,046 Answers
That is indicative of worn motors brushes or a speed regulation circuit board problem. It is worth getting it fixed.
I just checked and my diagnosis is sound :>)
I have a kitchen aid stand mixer. model #rkt2651x. it goes - Fixya
www.fixya.com/support/t26909658-kitchen_aid_stand_mixer_model
52 mins ago - i have a kitchen aid stand mixer. model #rkt2651x. it goes very fast when turned on then shuts off. it will go - Food Mixers question. SOLVED: Mixer goes really fast then stops
29 Dec 2007
Questions, Troubleshooting Help & Support Page 3
28 Jul 2006
More results from www.fixya.com
KitchenAid Classic Mixer K45SSWH Troubleshooting - iFixit
https://www.ifixit.com/Wiki/KitchenAid_Classic_Mixer_K45SSWH_Troubleshooting Make sure the KitchenAid Mixer is firmly plugged into a working outlet and the cord is not twisted or split. ... If your mixer still will not turn on, it might be a problem with the motor brushes. If the brushes are worn down ... The most common sign of a failing hall sensor is if your mixer increases to top speed and then shuts down. Missing: rkt2651x
Stand Mixer Shuts Off During Use - KitchenAid Product Help
producthelp.kitchenaid.com > ... > Stand Mixer Assembly and Operation Jul 12, 2017 - Once the steam has dissipated, the unit should turn on again (about 3 minutes). Resolution: If the mixer could have overheated during use let the mixer cool for at least 30 minutes and try to re-start. If you were making mashed potatoes when the mixer shut off it's possible that with excessive steam the unit ... Missing: rkt2651x
images for kitchen aid rkt2651x stand mixer goes very ...
More images for kitchen aid rkt2651x stand mixer goes very fast when turned on then shuts offReport images
FAQs - KitchenAid
https://kitchenaid.com.au/faqs Explore our range of frequently asked questions to get the very most out of your KitchenAid product. Missing: rkt2651x
[PDF]Classic Stand Mixer Speed Control - KitchenAid
https://kitchenaid.com.au/sites/.../stand_mixer_service_manual_speed_control_6-12.p... KitchenAid®. Classic Stand Mixer. Speed Control. Theory of Operation. And. Troubleshooting Guide. (revision date 6/19/2012). D. Pahl ... Mixer Does Not Shut Off page 6. Mixer Does Not Turn On page 7 ... the motor is not running (OFF) the governor ball plate is at its farthest forward position and when the motor is running at ... Missing: rkt2651x
How to Replace the Speed Sensor and Control Board on a KitchenAid ...
? 6:28
https://www.youtube.com/watch?v=41qTqTWQkMI Jan 15, 2013 - Uploaded by eReplacementParts.com
This video tutorial will show you how to replace the speed sensor and control board on a KitchenAid Pro 6 ...Missing: rkt2651x ‎turned kitchenaid rkt2651x stand mixer goes very fast when turned on then shuts...
Posted on Mar 10, 2018
5 Related Answers
Anonymous
  • 45 Answers
SOURCE: Kitcchen Aid mixer making a grinding noise
common problem. Worm gear & bracket #PS734273 about $36.
Posted on Nov 05, 2007
Anonymous
SOURCE: Kitchen Aid Stand Mixer won't release beater
I had this same problem as well.  The beater was stuck like glue to the rotating arm, and it would not budge with any amount of pressure.  I tried the cooking spray and it did nothing.  But today I put a rag in hot/boiling water and then carefully wrapped it around the top of the beater.  I let it sit for 10 minutes. Then I put the rag in hot water again and repeated the process for about another 5 minutes.  When this was done, I covered the beater in a towel (to protect it) and forcefully tapped (ok... I pounded) it with the flat side of my meat tenderizer (it was all I had...you could use a mallet or hammer).  It took a little bit of work because I had to hammer it from the bottom, then the side, then the top to get the little spoke guided through the shaft.  But it did finally come off.  After cleaning with hot water, I put the beater on again and noticed that it was still a little hard to get on/off.  So, I put a little bit of veg. oil on it, and it seems to be better.  Going forward, I will be sure to clean the top of the beater & arm after each use and then coat it with a little oil to keep from sticking.  Best of luck!
Posted on Feb 21, 2009
Anonymous
SOURCE: Kitchen aid stand mixer bought in US, moving to Europe, 220v 50hz
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
Hope this helps!
Posted on Jul 30, 2009
hslincoln
Howard Lincoln
  • 235 Answers
SOURCE: i have a kitchen aid stand mixer KG25HOXWH.
Hi ZPAORUSKI. I suspect your switch problem has to do with the speed control assembly inside your mixer’s head, and yes you can order and replace it.
The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case: KG25H0 (use zero and not ‘O’), and select one of the last two files listed under Parts List (9) (check to ensure this matches your mixer model. KA made a -4 series and a -5 series with slightly different insides, so make sure you have the correct Parts List manual.) For a series -4 mixer, turn to pgs. 2 & 3, titled Case, Gearing And Planetary Unit that shows an exploded view for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. No. 8, Control Assembly. This is where I suspect your problem lies. (For a series -5 mixer, turn to Pgs 4 & 5, and locate Illus. No. 18, which is the speed control assembly).
First inspect around the controller assembly to ensure that all the wire connections are OK. It's possible a connection has come loose. Unfortunately the whole controller assembly is fabricated on a little PC board filled with resistors, capacitors and other electronic parts, which was not meant to be 'home fixed'. My 'expertise' ends at being able to recognize a resistor from a capacitor, but I don't get much deeper than that. A local small appliance repair shop should be able to determine if the controller assembly is functioning properly or not.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping.
Once apart you can check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your mixer yourself.
If you feel troubleshooting and repairing is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping. Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Posted on Dec 03, 2009
hslincoln
Howard Lincoln
  • 235 Answers
SOURCE: Kitchen aid mixer drops metal shavings in the
Hi REDLACQUER. Sorry to hear about the metal shavings. This is probably not to best way to take iron in your diet... My first thought would be to ask if your mixer is still under warranty. If you’ve had the machine less than one year, then I’d let KA replace your mixer with a new one. However, I suspect like many who seek assistance from FIXYA.com, your mixer is out of warranty, so what can you do?
Have you been able to find exactly where the metal shavings are originating? From the symptoms you describe, it appears that the planetary/agitator shaft assembly may be rubbing against its housing and generating the metal shavings at higher speeds. Have you noticed any increased noise levels/squeaking/screeching when the planetary rotates? It’s also possible that the planetary is out of alignment and not rotating true. Could the agitator shaft been jarred or hit hard during set up or moving in or out of you storage cabinet? Or the shavings could be symptomatic of other internal gear problems, but that would be the least likely scenario as the mixers internal gears are pretty much self-contained.
The good news is that this can be troubleshot and fixed quite easily (OK, maybe with a little effort) by yourself if you are a DITY type person, and feel adventurous. However, before you start to disassemble your mixer, be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, KP2671, and select the last file, KP2671XWH3.pdf (325.07 KB) listed under Parts List (24) (check to verify that it matches your mixer model).
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. I suspect your Planetary Assembly, Illus No. 15, is rubbing somewhere against its housing, Lower Gearcase, Illus. No. 24.
To gain access to these pieces you’ll need the following tools: a regular or Phillips screw driver, retaining clip pliers, and a small drift pin punch and a small hammer. You need to remove the Transmission Housing (Illus No. 7) and remove all the lubricating grease from the transmission housing and gears (when removing the grease be on the lookout for shavings in the grease which would indicate excessive gear wear). This will allow you to remove Illus No. 25, 21, 18 & 19, Retaining Clip, Bevel Gear, Retaining Pin and Worm Gear Follower, respectively.
Once you remove the Retaining Pin (Illus. No. 18) the Planetary Assembly can be tapped down through the Lower Gearcase Assembly (Illus. No 24). With the Planetary removed, you can inspect it and the inside of the Lower Gearcase to determine where the shavings originated. Be sure to look closely at the Planetary Gear in the lower gearcase as well as the Agitator Shaft Pinion Gear (Illus. No. 12). That will also identify what parts need to be replaced, which you can order online.
You’ll need to replace the grease you removed with new grease. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call). Do not try to reuse any original grease as it may have ‘debris’ in it.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
If this solution was helpful, please rate it, thanks! – hslincoln
Posted on Jan 12, 2010
Kitchen aid model kb25gixob will not turn on.any suggestions?
Put an ohmmeter across the two pins on the plug, on the mixer,,not the earth one.and turn the switch on.you should get a reading,plus it will change as you turn the switch to different settings.if no reading,suspect broken wire in plug,or mixer windings burnt out.try in a different socket
Sep 12, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen aid mixer only goes 1 speed
The number in your question (9706529) is for the worm gear.
What is the model Kitchenaid mixer you have?
Jul 21, 2014 | KitchenAid 9706529 Stand Mixer Worm Gear...
The head of my Kitchen Aid stand mixer wiggles a lot when I us it
Put it upside down on a towel and tighten the hinge pin screw right up inside the pedestal. It's in the middle & retains the hinge pin.
Nov 30, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
I have kitchen aid stand mixer and i can't get the beater to attach because the button is stuck??
The button doesn't move. You must push the beater up beyond th notch and turn it while pushing up.
Jan 14, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
Who repairs kitchen aid mixers
Call the Kitchen Aid small appliance warranty office and they will tell you where the authorized repair person is that is close to you.
Dec 16, 2012 | KitchenAid K45SS Classic Stand Mixer
Mixer revs, then shuts off, will not reset
your kitchen aid has a little device inside called the hall effect sensor. These often come dislodged or just stop functioning. If you are mechanically inclined you can replace this yourself.
Oct 01, 2009 | KitchenAid KV25G0X Stand Mixer
Kitchen Aid 10 speed 325watts
Some of the gears may have broken or slipped off. You'll need t open it up to see why the shaft from the motor will not spin or you will burn out the motor with the power on trying to make it go. It might be a DIY job if you can see an obvious problem like a slipped gear, otherwise take it to a repair specialist.
Apr 30, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen Aid stand mixer just started going really fast at the lowest speed. I tried checking the sensor as some have suggested but is still goes really fast. It's only been used a few times. Is there...
Hi. Goto www.mendingshed.com , locate and download the free Kitchenaid Service Manual. This is a comprehensive manual and will help you with your task. You can also go to the Kitchenaid website and download the Parts Catalog for your mixer model.
If this solution has assisted you, please rate it. ricardok45.
Mar 10, 2009 | KitchenAid K45SS Classic Stand Mixer
Food Mixers Logo
415 people viewed this question
Top Food Mixers Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
john h
Are you a Food Mixer Expert? Answer questions, earn points and help others
