I believe that is standard plug for desktop computers. Any computer store or office suply store should havery it.
https://www.walmart.com/ip/3-Prong-Pin-AC-Power-Cord-Cable-for-PC-Desktop-Computer/49360006?wmlspartner=wlpa&selectedSellerId=1229&adid=22222222228036914916&wl0=&wl1=g&wl2=m&wl3=83293216354&wl4=pla-186604474354&wl5=9004519&wl6=&wl7=&wl8=&wl9=pla&wl10=112549857&wl11=online&wl12=49360006&wl13=&veh=sem
SOURCE: Power Problem. Sudden onset of laptop not coming
The most likely answer is the motherboard will need to be replaced. Here are some troubleshooting steps:
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
SOURCE: emachines T2042 does not power up. what could be
Not usually, what you need to do is see if the fan in the back of the PSU, runs at switch on... If it does NOT, there is a good chance your PSU has "Blown" this is a simple replacement, and quite cheap. You need to troubleshoot the PC, you need to also see if the fan on CPU goes at all, even a "Flick" at turn on? To see whats what, remove all Drives DVD and cards, then power on, if No GO then probably PSU.. IF OK replace things until, it stops, that is your problem.. Also remove a stick of RAM, and swap about if two to test them... A machine will boot with just RAM, but will complain..remove and introduce things one by one until you find problem, if you do all that and it is NOT, the, PSU, RAM, CARDS, HARD DRIVE, DVD, then it is your Motherboard. Try that see how you go.
SOURCE: My 360 won't power up. Orange light on power
Have a look into the usb ports on the front right of the console, look for any damage or bent pins, if any pins are touching this will cause a short, so the console will not turn on.
Or it could be an internal resistor problem, which would be best looked at by a pro repair center.
SOURCE: Hi, my HP Pavillion a1240n
There are only certain items that will not power up a machine. 1. The power supply itself could be gone. 2. Check your ram. 3. Your hard drive. In most cases it is the power supply. Take out the power supply from the machine and plug it in to a wall socket. If it starts that it is not the power supply. If it doesn't start replace the power supply.
